Subs and amp
Old 01-02-2008, 09:12 AM
Mtown's Avatar
Default Subs and amp
So today me and a bud are going to install my two 10" and my amp I have. I also have a Alpine 9883 HU, now I am pretty sure I can wire my system to my HU so that I can turn it on and off by using my radio. When I push the volume button in, it actually says " subwoofer" making me think I can adjust it fro 0 (off) or up to +7 or w/e it goes too..
So my question to you guys is what wires from my system do I need to hook up to my HU to make it function like I want? I was thinking the "REMO" wire but I am not sure...also any tips on making my system installation easier would be greatly appreciated..
Boy I sure have asked a lot of questions in car audio lately..haha
Old 01-02-2008, 09:40 AM
BIG_MIKE2005's Avatar
All you should have to do is install the deck like normal, run a remote wire from the deck to the amp & run RCA's from the deck to the amp. Thats it as far as the deck install.
For your amp run a short ground from somewhere in the trunk area(i used the spare tire well), hook up your RCA's, hook up your remote wire, run a fused power wire from the battery to the amp & your ready to run your speaker wire from the box to the amp.
Basic sub/amp installs are pretty straight forward. It can get complicated later when you have more than one amp, distrubution blocks & so on.
Old 01-02-2008, 09:41 AM
Mtown's Avatar
My alpine HU is already installed with the HUmount illumination thing as well.
Old 01-02-2008, 09:48 AM
so just pull it out, hook up a remote wire, RCA's & put it back in. Then run those to whatever location you want. that will have everything from the deck itself you need ran to your amp location.
Old 01-02-2008, 09:50 AM
Mtown's Avatar
Mmk..I guess I can buy remote wire at like Autozne or something..
Old 01-02-2008, 09:57 AM
KEE AUDIO's Avatar
Why are you having to buy a remote wire? What are you using to install the amp? A standard amp kit should have come with the remote wire already. It's the thin (16-18ga) blue wire. If you don't have an amp kit to install your amplifier I highly recommend you pick one up as using other types of wire may not work as well.
Old 01-02-2008, 09:59 AM
Mtown's Avatar
I am going to use a amp kit, I didn't know it came with the wire :o. So if I hook up the remote wire I should be able to turn my system on and off from my HU?
Old 01-02-2008, 10:06 AM
KEE AUDIO's Avatar
That's the standard way to install it. If it doesn't turn on and off with the radio you've done something wrong.
Also if you don't use a remote wire the amp won't turn on anyway. Power to the battery, ground a short distance from the amp, remote turn on wire are the three you must have hooked up to operate the amp properly.
Old 01-02-2008, 02:48 PM
letsrun97z's Avatar
also unless you bought really good rca's run them on oppisite side's power & remote and rca's on the other... also the 0-7 on your HU is for sub gain 0 meaning less bass and 7 being highest
Old 01-04-2008, 09:06 PM
Mtown's Avatar
Also, how do you go about running the amp cables, like the ones I have to hook up to the battery run them all the way to the trunk to the amp. Basically, got them hooked up to the battery..then got stuck..can't actually get the wires into the car to run it under the carpet and what not...I am not very good with electronics...
Old 01-05-2008, 03:35 AM
KEE AUDIO's Avatar
First of all I hope it isn't hooked to the battery yet. Just in the engine bay by the battery. The grommet for entry through the firewall is located behind your PCM (computer) on the passenger side. You need to remove it in order to gain access behind it.
How many wires are you refering to. Should just be the power wire that you have to run through there for the amp.
Old 01-05-2008, 04:20 AM
Mtown's Avatar
Yes it is just the power wire and no it isn't on the battery sitting there xD. What does the PCM look like or what is it buy so that I can find it easier.
Old 01-05-2008, 04:38 AM
KEE AUDIO's Avatar
Here you go:
Old 01-05-2008, 04:39 AM
KEE AUDIO's Avatar
Yours may look different...but it will be in the same location.
Old 01-05-2008, 04:44 AM
Mtown's Avatar
Your so smart! :o, is there a write up somewhere on how to install subwoofers properly?
Old 01-06-2008, 04:00 AM
Kage's Avatar
Cool
Are u using remote wire or ant. power wire?
Old 01-06-2008, 04:30 AM
Mtown's Avatar
Well tonight me and a bud took on the task! We got the power wire ran all the way from the battery to the amp(not hooked up yet though) and hooked the RCA's to the HU and ran them to the back as well along with the remote wire. Everything is right by the amp just need my box and hook up the speaker and I am done! I think!
Old 01-06-2008, 04:40 AM
Kage's Avatar
Cool
U R using a power wire fuse by the batt right??
Old 01-06-2008, 04:36 PM
Mtown's Avatar
Yes I have that sitting in my bag , not hooking it up or anything to the battery until I get my box.
Old 01-19-2008, 04:14 AM
Mtown's Avatar
Well this is a little delayed but I got my subthump box in sometime last week and finished the install and it works and sounds great =D thanks guys for those who answered my questions! Who needs best buy when you have ls1tech!!
