head swap, bolt hole and coolant question
Old 01-05-2008, 08:17 PM
dubrado's Avatar
Default head swap, bolt hole and coolant question
Someone suggested to me to tap the bolt hole to get the crud out...sound good? will it work?
Old 01-05-2008, 08:27 PM
ssheets's Avatar
The best way to do it is to tape up a straw to a vacuum claner hose and suck them out. Then run a chase them with a tap. The straw on tha vacuum cleaner is a must.
Old 01-05-2008, 08:30 PM
Tainted's Avatar
or use an air hose and blow them out and put a cloth down into it. Also, take a stock head bolt and grind 2 flat faces on it and use that to clean out the holes. yoou cant have any liquid or dirt in them
Old 01-05-2008, 08:31 PM
NHRAFORMULA00's Avatar
Just use air compressor, Meanards has a cheap air blower 5$ that is about 12 inches long,bend it to fit all the way down to bottom of bolt holes.Dont forget to clean out bolt holes with an old bolt . Cut 2 grooves the lenght of bolt in the threads for the crap to accumulate, and run it in and out several times, then blow out with air.
Old 01-05-2008, 08:49 PM
dubrado's Avatar
so a tap will help take out the crusd correct?
Old 01-05-2008, 08:50 PM
dubrado's Avatar
Isn't that basically what the tap would do?
Old 01-05-2008, 09:51 PM
DaveX's Avatar
A tap isn't going to get the coolant out. I used a straw and my air compressor to blow them out. You need to be 100% positive you get all of it out or you will crack the block when you put it back together.
Old 01-05-2008, 09:52 PM
chrs1313's Avatar
if you are set on using a tap use it but good advise has already been given...
Old 01-05-2008, 10:07 PM
Grimes's Avatar
tap wont get all the fluid out, it will stay on the sides of the tap that are hollow. just get some compressed air or use a vac, as already stated
Old 01-06-2008, 11:56 AM
jshelton2006's Avatar
get a can of air duster. the straw on it will go to the bottom of the holes, then grind2 sides off an old head bolt and run it in and out a few times.
Old 01-06-2008, 11:58 AM
JMBLOWNWS6's Avatar
My buddies and I have done about 20 to 30 head swaps. We just use air and blow the holes out. Never have had a problem.
Old 01-06-2008, 12:05 PM
Restricted User
socmguy's Avatar
Don't worry about that coolant bro, just bolt it all back up.
Old 01-06-2008, 04:52 PM
dubrado's Avatar
the tap will atleast get the dirt or grime out the threads though right?
better than the bolt w/the grooves?
Old 01-06-2008, 04:59 PM
JMBLOWNWS6's Avatar
I hope you know you need a special tap to even do what you want to do. Not something sold locally.
Old 01-06-2008, 05:01 PM
dubrado's Avatar
ya, it'd have to be pretty long to work.
worse case is if I can't find it, I'll do the bolt deal
but in case I can get one, I wanted to know if it would work well...I think some confusion in the thread came in when I put coolant, meant to put dirt and particles.
Old 01-06-2008, 05:05 PM
JMBLOWNWS6's Avatar
95% of the time the holes are not contaminated. Just inspect each bolt when removing them. Then I just blast them with my air gun to make sure the holes are dry. If not the bolts will not seat correctly. Are you using head bolts or studs? I perfer studs.
Old 01-06-2008, 05:06 PM
dubrado's Avatar
bolts, I don't plan on swapping heads again and when this motor is done, I'm gonna just get rid of it for a pre-assembled shortblock or long block.
Old 01-06-2008, 05:07 PM
JMBLOWNWS6's Avatar
With the spray and the 243's I would highly suggest ARP head studs. They will hold up better to the spray.
Old 01-06-2008, 05:09 PM
dubrado's Avatar
I already have the bolts.
Old 01-06-2008, 05:13 PM
JMBLOWNWS6's Avatar
I just hate putting so much stress on the threads when doing the bolts. I like the studs. You will be fine. Make sure to use ARP moly lube.
Quick Reply: head swap, bolt hole and coolant question
