do you have to pull the motor for cam swap????
www.ls1howto.com
the link to a cam swap in an F-body is on the right hand column
just take the radiator out and u'll have plenty of room..you can leave the AC condenser in
One tip from my swap using LS1 how to is to jack the car up on the pass side. Unbolt the 4 bolts in the ac compressor and move it forward to take the pressure off the lines. Then move the condensor toward the motor a little and let the condesor lay on the ground. This worked really well for me.
