how many miles when your rearend went?
Old 01-07-2008, 02:28 AM
MuscleCarZ28's Avatar
Default how many miles when your rearend went?
For those who have blown there stock rearend with a A4, how many miles did you have? I just picked up a 2001 z28 A4 43,000 miles and plan on doing my best to make the stock rear end last. I am just going to do basic bolt ons and don't plan on driving it really hard. But just curious to know how many miles you A4 drivers had when it blew. did you race it hard for this to happen? or had a lot of hp? let me know how you guys ended up blowing them. I hope to get another 40k miles with about 350whp and not much drag racing. possible? i have read all these stories of rear ends blowing and its got me scared because i won't have 2-3k for a better rear end till i graduate. Thanks, Dan the noob
Old 01-07-2008, 04:53 AM
Bird Man's Avatar
Depends on if you got a good setup from the faactory. Mine has been replaced 3 timesand I just drive normal.
Old 01-07-2008, 02:56 PM
Jays00ss's Avatar
38,000 but I elected to swap it out in favor of a 9".
There was nothing wrong with it (Other than being a 10 bolt) and I just put 3.90 gears in it at 35,500. I ended up selling it with the stock gears added in for $525.
Old 01-07-2008, 03:24 PM
RAGENZ28's Avatar
I don't have an A4 but I still have broken gear stories, I have in a 10 bolt broken 3.42's, 3.73's, 4.10's and 4.56's.
I broke the 3.42 (stock gear) around 8,000 miles, which is 3,000 more than the factory clutch lasted
Some times racing, sometimes just taking off hard at stop lights and No matter what luck anyone has had, you beat on it it will break guaranteed.
100% of my failures were teeth breaking off of either the pinion or ring gear.
I am personally going with the S60.
Old 01-07-2008, 03:28 PM
wrd1972's Avatar
May the GM engineer that put the 10 bolt in the F-bodies burn in hell a thousand times over.
Old 01-07-2008, 08:11 PM
2 SSlow's Avatar
100,000 miles when my rear end ****...over 40,000 cammed...over 60,000 HARD miles in 2 years lol
Old 01-07-2008, 08:36 PM
michaelg589's Avatar
Mine never really broke. The diff. seemed a little "shaky" and I wanted a steeper gear ratio so I replaced them with 3.90s. I put the 3.90s in at about 88000 miles I think. I also have an M6 which is little more abusive on drivetrain components. It really is luck of the draw with the 10 bolts. Some can handle low 11 sec passes, others break on bone stock cars going mid to high 13s.
Old 01-08-2008, 05:03 PM
i should of got the warranty they offered me
Old 01-08-2008, 07:28 PM
keliente's Avatar
It probably wasn't worth it (most aftermarket warranties aren't).
Rear ends don't crap out at a particular mileage...it often has a lot more to do with how hard the car was driven. If your rear isn't making any noise now and you don't plan on racing it every week, you'll probably be fine for a while.
Old 01-08-2008, 07:33 PM
bad6as's Avatar
my stocker had over 80K and it was still alive
Old 01-09-2008, 09:33 PM
brandons02's Avatar
A4 with stock 10 bolt with 58,000 that was three weeks ago and tonight it started clunking again,I dont beat it either, daily driver, so back to the Chevy dealership I go, with my warranty.
