Custom grind. What do you think.
Im going to be getting a custom ground cam. The specs are 234/240 603/611LSA110+2. What do guys think? good choice? It's really similar to a g5x2
LT's, ORY, LS6 intake, P&P TB, Cat-back, Ls7 clutch. Then im also doing all the springs, pushrods, oil pump and everything else required for a cam swap. Then depending on how it drives after the tune i will probly throw some gears in the rear.
