LS6 valley cover mod ? for better oil control?
Check LS1howto.com they list all the parts you need. You can get them from SDPC or GMPartsDirect.com I plan on doing the pcv conversion when I do my intake swap.
I did it, I burn slightly less oil, maybe 1/2 quart every 2500 miles and I don't ping uncontrollably anymore. But I did a bunch of mods and who knows which is responsible for that. I believe the valley was 60 bucks from SPDC and I just used fuel hose for the the PCV. It's very easy if you don't have to cut your block, I had to cut it and I would still do the mod. Removing all those damn PCV lines was worth it alone.
If you are going to add boost you'll need to upgrade the pcv system. It puts alot more pressure on the crankcase. In some cases guys are popping the dipstick out under higher boost. Anything is going to help.
I run LS6 setup on my 370 iron. The trick to fully benefit from it is to run the proper LS6 PCV valve. If not and running LS1 valve it will not do its function properly and will be less effective.
http://www.ls1howto.com/index.php?article=18
Thank you very much, looks pretty eazy, I guess with my set up (Supercharged) procharged i would connect that LS6 valley cover port to my existing AMW catch can and then down to the Procharger inlet hat, With this set up i do not run the PCV valve,
If i am wrong please let me know
Here is a picture of PCV setup, catch can and Z06 valley pan:
http://www.putfile.com/pic.php?img=7299774
For non-FI the air goes into the block from the throttle body to the passenger front cover. It gets pulled out of the Z06 valley pan by the intake vacuum.
