Mild Cam for '04 GTO LS1 w/Z06 heads
Hello, I have a '04 LS1 from a GTO for my S10 truck. I've installed Z06 heads on the engine and am shopping for a cam. I'm looking for a mild cam, something better than the stock Z06 cam that can still be smogged with a good tune since I live in CA. So far I've been looking at the Trick Flow Track Max stage 1 (216/220 @ .050, .560/.560) and the Comp Cams 269 Xtreme (216/220 @ .050, .525/.532) Which one would be better for street and occasional strip use? I know you guys like big cams around here but it has to be smoggable. Thanks in advance for any help.
They say the Thunder Racing TR224 114lsa is the biggest cam (with a good tune) that will pass CA smog. I'm not sure though so I would research it if I was you. Maybe ask in the local CA rooms for guys that have done it.
Thanks for the help guys. Didn't mention it before but I'm looking for a wide power band.
thanks for the help. I'm in the process of installing a set of yella terra 1.7 rockers. Will I be able to re-use the stock rocker bolts or would I have to buy a new set? the engine has 22k.
thanks for the help again CamaroSS. how many horses you think my combo is good for? '04 GTO LS1 (LS6 intake manifold), '04 Z06 heads, yella terra 1.7 rockers, intake, headers, exhaust, and the TR224 114 LSA cam you recommended
If you want a mild cam, that gives great power and still idles like stock, look at MTI's Stealth II cam. I have it and it's great for being a daily driver. Idles perfect. Only if you really really listen can you tell there's a cam. But, above 2500 rpm, it pulls HARD to 6500. It's a nice comprise cam. My signature has the numbers. This is still with factory exhaust manifolds. Headers are next on the list!
