coolant lines question
LS1TECH & Trucks Sponsor
The coolant lines under the intake are different.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
LS1Tech Premium Sponsor
They're different but so similar that you can use either on either setup. To use the LS1 lines on the 5.3L it will require an ever so slight bend to that line. It's nothing major and it wouldn't crimp it or anything. This is due to a VERY slight different in that area on the head. Nothing serious, run whichever you want. We keep the LS6 pipes/plugs in stock if you want them!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The way I look at it the more of those avatar's running around, the better.
Using the LS1 lines on a 5.3 was mentioned up above. So there is a little bit of modifying involve in this? Reason I'm asking is I gave my LS1 intake and coolant lines to my brother for a future mild 5.3 build, the more info we know now the better.
