LS1 Sheet Metal DP
LS1 Sheet Metal DP
Since some of you guys dont make it over to the nitrous section all that much...
Three total DRY stages, two via the plate and one via the direct port. All three stages are controlled through our in house controller, the Interface's big brother. I'm going to try to post of some picts of some others in the pipeline, a few more sheet metal and some FAST's. I'll try grabbing some of the 105mm sheet metal that is being finished up now, which has two wet direct port stages.
Higher res picts can be found here:http://www.harrisspeedworks.com/gall...s.php?album=58
Nick
Nick
