Plug coolant pipes???
Old 01-16-2008, 06:20 PM
Mike Cordero's Avatar
Default Plug coolant pipes???
If I eliminate the coolant pipes in a LS6 to plug and by pass them, that won't do any harm? What is the purpose of those coolant pipes? sorry for this dumb question.
Old 01-17-2008, 05:27 AM
Default Plug Coolant Pipes
Some Light Here Please, Thanks.
Old 01-17-2008, 10:57 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default coolant pipes
If you are referring to the small diameter steel tubing on the intake face of the heads, they are vapor recovery lines. It is the way to get steam pockets out the the heads and recondensed back to liquid in the coolant recovery tank. Leave them alone.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 01-17-2008, 10:59 AM
99mongooSS's Avatar
yeah dont mess with'em
Old 01-17-2008, 11:20 AM
I was told that LS1 brought the coolant pipe under the intake (from front to back of the engine), but later, for use with LS6 intakes, now a by pass in front and some plugs on back are used; so the old coolant pipe is removed. If this coolant pipes recover vapors from heads (in front and back of them) why now GM just plug the back part and by pass in front. This won't hurt in any way?
Old 01-17-2008, 12:02 PM
LS1TECH Sponsor
Default Vapor recovery tubes
Mike,
There is a patent issue with those tubes. Evans Cooling holds the patent on the original layout. GM may be trying to get around the patent with the change. Evans has sued GM over this.
Steve
__________________
Steve Demirjian
Oceanside, Ca.
760-630-0450
Old 01-17-2008, 12:05 PM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
If you have an LS1 it runs under the intake and all 4 are connected.
If you have an LS6 the fronts are connected and the rear two are plugged
In the case of an Ls1 you can plug the back two and just connect the fronts, but if you have an LS6 you should leave it the way it is
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 01-17-2008, 01:10 PM
M K S's Avatar
Exactly correct. I have the back two plugged on my '98 and have had zero issues with it.
Old 01-17-2008, 02:15 PM
Viper's Avatar
I've got an LS6 block with AFR heads, LS6 intake so I plugged the 2 in the back.
Old 01-17-2008, 07:13 PM
Default plug coolant pipes
Thanks to all of you for your help and teaching.
