Just asking?
Old 01-17-2008, 06:56 PM
crapyboy750's Avatar
Default Just asking?
My friend got a cam which he installed in his 01 m6 trans am. Am he got it tuned at MTI and he was telling me that when he would back up is car would sometimes stall out. Is that normal, should it still sometimes stall out even with a tune?
Old 01-17-2008, 06:58 PM
BLACK2001SS's Avatar
Mine can stall sometime you have to let it warm up more I think thats the Key, the car is a little diffrent now got to let it warm up.
Old 01-17-2008, 07:07 PM
o well im getting my cam pretty soon but i have an a4 with a 3200 stall do you think i will have the same problem with the stalling in reverse?
Old 01-17-2008, 07:09 PM
john563's Avatar
my car did that sometimes before. My tuner made some corrections and now it does not.I'm heads, cam ,intake,and a stalled A4 too
Old 01-17-2008, 07:19 PM
the idle could be set too low also look at his RPM's what are they at sometime guys like more loapy sounding so they bring the rpm's down Mine is at 800 I belive some guys are at 900.
Old 01-17-2008, 07:25 PM
waterbug1999's Avatar
This all depends on what size cam you get and the tuner, the bigger the cam the harder the tune... MTI, I am sure can tune it pretty good but dyno tune and real world tune are different and takes time to wrinkle out the bugs. Get EFI live and do it your self.
Old 01-17-2008, 07:30 PM
04goatman's Avatar
I have a mild cam 222/224 566/568 112 LSA my engine dies when i rev up the rpm & as it descends it dies. My idle in drive is set at 950 rpm. I haven't had a chance to take the car back to the tuner to fine tune it. I don't know much about mods but it seems to me its not right the car idles at 950 rpm in drive.
Old 01-17-2008, 07:55 PM
Definately not right... IT takes time, that why you should buy EFI live and learn and tune the car yourself.
Old 01-18-2008, 08:40 AM
radkon's Avatar
+1 but I use HP tuners. When I first had my car tuned it would die unless it was warm. My cam isn't big at all (TR224 112). I wasn't happy with it so I learned to tune it myself. Turns out my tuner never adjusted my VE table which needs adjustment if you put a cam in. A lot of tuners don't bother with this since it takes time. Once I got that table squared away the car purrs like an angry kitten (nice lope). I was even able to lower my idle RPM to 750.
