SS wheels on a 2wd S10
Old 01-19-2008, 09:12 PM
JGKadell's Avatar
Default SS wheels on a 2wd S10
What size adapters do I need?
I was not sure if this belonged here or in the wheels section.
Old 01-19-2008, 11:17 PM
turbo.trex's Avatar
I think they bolt right up,the camaro is on the small bolt set I might wrong
Old 01-20-2008, 12:21 AM
jeep0084's Avatar
Bolt pattern is the same but you might need spacers. I know third gen wheels bolt right on but third gens need 2 inch spacers to run 4th gen wheels.
Old 01-20-2008, 09:25 AM
JGKadell's Avatar
Ok, I know a 4th gen F body wheel will fit a 4WD S10/Sonoma without a spacer. I want to know exactly what size spacer I need to make them fit properly on my 2WD 94 S10 beater truck. I have a set of 17x9 10 Spoke SS wheels for it.
Old 01-20-2008, 10:52 AM
z2fast8's Avatar
just a 1 inch
Old 01-20-2008, 11:00 AM
philntx's Avatar
You should probably go over to this forum:
http://www.s10forum.com/forum/wheels-tires-and-brakes/
These guys have installed just about every combo of wheels/tires on trucks...stock, raised and lowered.
Old 01-20-2008, 02:59 PM
JGKadell's Avatar
I posted over there. I just don't care for that forum. I get tired of them calling and S10 a "dime".
Old 01-20-2008, 03:10 PM
almostfast's Avatar
should be 2" spacers... i know those wheels fit correctly on 4WD S10's(which are 58" wide (i think)... and the 2wd rears are 54.5" wide, so 4" divided by two= 2"
you should be able to use anywhere from 1.5" to 2.5" thats why i would go with 2"... right in the middle
Old 01-20-2008, 08:40 PM
philntx's Avatar
I believe that this one used 2" spacers front and rear:
http://www.v8s10s.com/id20.html
Old 01-20-2008, 09:38 PM
JGKadell's Avatar
thanks Phil
Old 01-20-2008, 09:50 PM
JGKadell's Avatar
A guy on the "dime" board said he had them on his truck and he ran a 2.25" spacer. I also emailed the v8s10 guy.
Old 01-20-2008, 10:04 PM
96lt1m6's Avatar
2.25 spacers up front,they will rub inner wells doing a U-turn.the rear has an 8.5" rear from a mid 70s camaro.an 8.8 will work also if you change to gm bolt pattern..
Old 01-20-2008, 10:07 PM
JGKadell's Avatar
The guy from v8s10 said 2.5" on all 4.
Old 01-21-2008, 05:24 PM
philntx's Avatar
If you use a 4WD S10 Rear Axle, it's the correct width to run those wheels without spacers. (not the ZR2 Axle, it's too wide)
Old 01-22-2008, 01:51 PM
TRANSAM75's Avatar
Yeah, you can pick up a used 4x4 posi rear for the price of two spacers if you dont already have a posi.
Old 01-22-2008, 02:01 PM
96lt1m6's Avatar
i spent 65.00 for the aluminum adapters NEW shipped off e-bay.
the 2.25 up front keeps the tire in the fenderwell!the 2.5 will let the sidewall poke out some,the rear can handle the 2.5 adapter with ease......
Old 01-22-2008, 02:08 PM
Blindmelon's Avatar
You don't just get any type spacer but a machined adapter if going over a 1/2" for sure. The best bolt pattern to go to is the 5x4-3/4" then all the knock off Vette wheels in almost any size width for cheap. I am using these guys to make a adapter to put Z06 18x10" on my 6 lug SSTB. Do it right.
http://www.skulte.com/index.php/cPat...5fd265a726147b
Wheels
http://www.factoryreproductions.com/...vette&wheel=11
Old 01-22-2008, 02:32 PM
96lt1m6's Avatar
the adapter/spacer i bought is very nice quality billet alum. i am quite satsfied with them,i do understand that there are some JUNK ones out there!
Old 01-22-2008, 03:05 PM
slimcracka's Avatar
i had chrome zr1s on my sonoma (96) and it had 2.5" billet spacers on all corners..and had a nice stance too...
Old 10-22-2017, 08:56 PM
Mike ctsV's Avatar
Grave digging. Need some help. Can anyone tell me what wheel spacers i will need for my 02 s10 2wd base model, stock height, in order to put the american racing torq thrust i got off my brothers 00 trans am. The wheels are 17x9 with 45 offset and the tires are 245/45/17. The fronts dont fit, didnt try the rear, but the front the hub didnt fit inside the wheel. So i cam tell i need some kind of spacers
Quick Reply: SS wheels on a 2wd S10
