Thoughts on this heads / cam combo?
PP S2 035 casting heads with 2.02/1.57 valves and welded 59cc combustion chambers with a T-rex cam. Will I still probably need to fly cut or might these fit w/o cutting? Will my compresson be ok with this setup? I usually run only 93 octane in the car as is. Anything else I might need to be concerned with with going with a 035 casting vs a 243?
