90mm Weiand/Holley aluminum intake manifold?
has anyone attempted to take an aluminum weiand/holley intake and modify the throttle body area to a 90mm. i have one and i think i am going to try it and wanted to see if anyone else has done it and if so what kind of gains they have recieved. pics would be nice if there is someone out there that has done this. thank you.
I have one as well..I thought about it and mocked up a 90MM throttlebody..It would have taken alot of work. The snout is too small. You would have weld up a new mounting plate for sure.
I also ported the snot out of mine...The port exits are smaller that the stock heads ports. Looks like it was designed to be port matched...Also ported the radius turn in the runner it was way to small...
Unported..
ported to stock head ..
unported radius...
ported..
Unported..
unported radius...
ported..
I haven't seen one of those intakes in years
Unported..
unported radius...
ported..
Unported..
unported radius...
ported..
thank you for replying with the photos. i will post some as soon as i am done with mine. it will probably be a couple more days. i am also polishing the intake to a mirror finish.
i finished welding and polishing the intake today. i just need to drill and tap the holes for the front throttle body area and put a final buff on it and i'm done. pics by the end of the week.
I've also got a filled, smoothed & ported 90mm LS2 intake & am conflicted between the two set ups. Currently, the Weiand is in place.
I did close to what you are requesting. However, I only opened it up to 85mm & used an 85mm 3 bolt TB, I think bought from Summit. It was a while ago & can't remeber for sure, but, probably was Summit. Also, the runners were opened up to port & gasket match similar to what is shown above. Everything that I've read shows some level of improvement from increased inlet sizing on the Weiand & LS6 manifolds.
that was a delema for me i knew that i could go with a 85 and stick with a 3 bolt pattern and not have to do much work other than increasing the diameter from appox 75 to 85mm on the throttle body opening but i really wanted the 90 mm which does create alot more work but in the end it should help out alot. plus it looks cool.
does the ls2 intake flow better than a ls6 or the weiand? if it isn't a great improvement i would stick with the weiand.
