OBD2 Diagnostic Plug Wiring
Old 01-23-2008, 08:20 PM
Trunknuts's Avatar
Default OBD2 Diagnostic Plug Wiring
I used a reworked harness for my LM7 (5.3L Tahoe engine) which did not come with a OBD2 diagnostic plug (under-dash plug). I purchased a plug with about 10" of wiring w/ it. Can anyone tell me how to wire it in. I looked in the manual but the schematic shows a "splice connector" between it and the PCM. Can the plug wires go straight to the PCM? And if so, what is the pin out? Thanks in advance for any help.
Old 01-23-2008, 08:54 PM
cherryelky305's Avatar
my experience is with a camaro harness. however I believe that the general rule is that OBDII ports have 4 wires. two grounds, a constant 12V, and the data line. Wish i could help more, but i dont have my diagrams with me at the moment.
Old 01-23-2008, 09:11 PM
jay_lt4's Avatar
pin 2 class 2 serial data
pin 4,5 ground
pin 16 12v+
Old 01-24-2008, 04:48 AM
samdogmx's Avatar
here you go
Old 11-19-2008, 04:48 PM
wajouba's Avatar
Ok, I have a 240sx with an LS1 swap, and my car is very unstable... I really need to know what codes its firing up at me, but my OBD2 Connecter is not connected... my question is, where is the purple data line located?. do we take it from the original LS1 car dash harness? or is it in the ECU harness?
Thanks
Old 11-19-2008, 05:05 PM
sawzall wielding director
G-Body's Avatar
The purple serial data wire comes from the LS1 PCM. If you look at the diagrams in the FAQ sticky you should be able to determine which pin it goes to. If not, you need to tell us what year PCM and wiring harness you are using so that we can tell you where to look.
Old 11-20-2008, 02:48 AM
wajouba's Avatar
how can I know whether my engine came from a 99 or 98 camaro? cause I saw the PCM pin outs before but didn't know which one to use... can you guide me on this?
Old 11-20-2008, 08:22 AM
oange ss's Avatar
does your ECT connector have 2 pins or 3 ?
Old 11-20-2008, 03:14 PM
wajouba's Avatar
whats an ect? :S pardon my dictionary of abbreviations
Old 11-20-2008, 08:05 PM
oange ss's Avatar
Engine Coolant Temp sensor, front sensor in the driver side head
Old 11-20-2008, 08:18 PM
wajouba's Avatar
it has 3, with the green that connects to the dash for reading of temp... but I heard 99s also have the 3 wired one... so what is mine 98 or 99?
Old 11-20-2008, 08:54 PM
oange ss's Avatar
only 98 has the 3 pin ECT sensor, 99+ coolant guages are PCM fed...so you have a 98 engine/harness
Old 12-10-2008, 05:52 PM
wajouba's Avatar
Alright, so I have a 98 harness and PCM, where is my serial data pin on the PCM?
Old 12-10-2008, 06:24 PM
oange ss's Avatar
C2 (blue connector) pin#58, purple wire
Old 12-10-2008, 06:43 PM
wajouba's Avatar
ok about the ground wires... both Chassis? or does one have to be from the ecu ground?
Old 12-10-2008, 07:46 PM
oange ss's Avatar
ALDL pin #4 chassis ground
pin #5 signal ground (ECU)
Old 12-12-2008, 07:57 AM
Speed Demon's Avatar
What is the difference between a signal ground and chassis ground?
I know what a chassis ground is.
Old 12-12-2008, 08:14 AM
wajouba's Avatar
I have the same question in mind... so is a signal ground a ground comming from the ECU/PCM or comming directly from the negative of the battery? (which is actually chassis I think)...
Old 12-12-2008, 08:26 AM
I know on the BMW DME (PCM) it has serveral grounds that are switched ground/open by the PCM to control relays. I see in the F-body PCM pinouts that is has several grounds, are some of these switched (or signal) grounds?
Old 12-12-2008, 08:46 AM
wajouba's Avatar
yeah for example the pin number 60, on the blue connecter right beside the Serial Data, is this what we call Signal Ground? :S
Quick Reply: OBD2 Diagnostic Plug Wiring
