Western Members CA, AZ, NV, UT, CO, NM, HI
help with a nissan!
Old 01-23-2008, 08:51 PM
pweterss's Avatar
Default help with a nissan!
ok-my mother in law has a 97 nissan altima 4 banger,it runs fine but sometimes it just dies out!it will shut off at a stop and will start back up no prob.it just got a tune up and fuel filter,what do you guys think? fuel pump?any sensor you think it might be? Thanks!!
Old 01-23-2008, 08:57 PM
wickedbluess's Avatar
My Buddy Had An 05 That Did The Same Thing Your Saying ! It Ended Up Being The Trans, It Was Going Out Or It Was F@#$ed Up ! You Know Him Shorty The Guy Who Rode With You To The Spectrum !
Old 01-23-2008, 09:03 PM
pweterss's Avatar
the tranny??? thats f$% wierd!
Old 01-23-2008, 09:46 PM
MJs1FastSS's Avatar
sounds like a sensor to me.... my gma had that problem.....and it was like a 50- 100 part
Yea Thats What I Said , We Checked The Alternater & Replaced The Battery ! Nothing , Same Problem . Then Took It To The Dealer They Said It Was The Tranny
Old 01-23-2008, 10:42 PM
pweterss's Avatar
il get the tranny checked,i just went to pick up a fuel pressure guage ill check it tomorrow and see what happens. Thanks guys!
Old 01-24-2008, 01:50 AM
m_ghonim's Avatar
that is most likely to be the fuel pump just seen that about two months ago or so same symptoms.
Old 01-24-2008, 09:36 AM
8tsixt's Avatar
I have a friend who works for Nissan. He said start by checking the distributor. Check for any signs of oil on there. There is a ring in there that tells the ecm/injectors when to shoot fuel. He is about 99% sure that is your problem. There is a seal in the distributor that is not sold seperately and you must buy the whole distributor. Pm me if you have any other questions with it.
Old 01-24-2008, 11:33 AM
camarojunky74's Avatar
bring it to me today or tommorrow if you can ill take a look at it i have a few ideas, check the maf, check the dist secondary ignition, check for maybe the converter locking up, check the tps, check the iac. **** man i could go on and on, bring it by ill take a look at if for ya
Old 01-24-2008, 11:36 AM
oh also these cars have a problem with the dist getting oil in them and blocking the optical sensors, this can easily create your problem,
Old 01-24-2008, 08:35 PM
SSMOKIN_Y2KSS's Avatar
maf if more than likely the issue here...
Old 01-24-2008, 10:05 PM
NovaTodd's Avatar
Didn't Nissan just have a recall on the crank position sensors? Seems like the symtoms were exactly what you are describing. It's worth checking on.
Old 01-25-2008, 12:14 PM
yeah there is tons of possibilites im leaning more towards the optical sensors being covered in oil, there is no recall on the ckp, just a tsb
Quick Reply: help with a nissan!
