Huge A/F change above 5500rpm..
One of my friends thinks I was spinning the tires and probably did not know. I have spinned them on channel 2 in 4th around 5500rpm, but not off the wastegate spring. My car sits at 12.5 to 13lbs off the wastegate spring, but I was spiking the boost controller up to 16 and 17 last night. I had the meth all the way up and one point to see if anything would change and it made the car super rich and then leaned to 12.5 up top. I looked at the PE table and it does add fuel in that range. I can add more to be on the safe side. I really just need to get the 3 bar SD tune done.
I dont go WOT very often. I just put in a Tex Twin Disc clutch, but I also noticed the air/fuel going up like that on my old clutch and just thought the clutch was slipping because I could smell clutch. This time I dont smell clutch. I had a mishap early last year and it was discovered I had a bad lifter. We repaired the bent valves, replaced the lifters and removed my old suspect cam just in case it was damaged. I am still running that exact same MAF tune as b4. I have no doubt it needs some tweaking. I just want to make sure everything else is ok b4 taking the road trip to get the 3 bar SD done.
Did you pull beyond 5500 rpms or let off each time it got there and the A/F went to 12.5 each time no matter what the meth was set too?
Make another pass with no gain and base meth settings. Does the car pull past 5,500 rpms? Need to validate that there is no valve float.
Rick
Vince, are you talking about being on 16 or 17lbs of boost or you just turned the gain up on your boost controller to 16 or 17? Figure a 16-17 gain on a cold night put you at about 15lbs of boost?
Rick
Rick
Coal Mining Director
Trying to run 12 psi to 17psi on a single maf/PE tune is crazy. If you tune it for 17psi it will be crazy rich at 12psi. If you tune it for 12psi it will probably go crazy lean at 17psi and B L O W.
It spiked to 17psi, but did not hold 17psi. I know that it's rich at the lower boost setting. The car has been running this same tune since day one and it has seen over 900rwhp on a loaded dyno w/out any issues and the a/f was fine. I recently repaired a boost leak, but I could not get on the car because I was breaking in the clutch. Well doing short spurts I noticed the car was feeling a little sluggish. I did get on it some post repairing the boost leak and it responded well. Over time that new hose I replaced blew off. This was discovered like 20 minutes ago. That hose comes right off the turbo and goes toward the intercooler. I think that is my air/fuel issue.
The boost controller is a Blitz SBC i-D III (maybe a color one) multi channel controller guys. Flipping through the **** adjusted menu has been known to cause opps when distracted on the road or the pits. I've been there. So Given no changes to the tune and no intentional changes to the settings on the boost controller, there may be an accidental change to the boost controller that is getting to you. So it would help to review the controller settings when you get a chance and post them here.
The boost controller has an Auto and a Manual mode. The Auto mode has a learning feature that allows the controller to learn the car and provide an easy "tuned" approach to reaching the boost target. The auto mode does not work well with dual turbo setup or higher boost settings. There is too much room for error in most cases. The Manual mode does what you tell it to do and is used by most of us with these controllers. So that's a potential opps if you go from Manual to Auto mode and the controller is learning which could cause the spike. This setting is under the Main Menu... Boost... Auto/Manual menu item.
The Manual mode can be set to different gain levels on each of its 2-4 channels (depending on the model). This allows you to quickly move between preset boost levels and use the scramble modes with timers to switch on the fly. The trick is that you have to be careful when selecting the channel or changing the gain for a selected channel at the main display rather than using the Menu items to make these changes. It's just easier to make a mistake at the Main Display and not realize it.
The tune would have been set for the highest gain settings probably set on Channel 2 originally. Let's say 0 gain on channel 1 gives him his normal "on waste gate spring" setting of 12.5-13lbs of boost. Then channel 2 might have the gain set to 20 to allow a 15lbs boost target. We just need to confirm what these current gain settings are to do the math for the target boost.
The controller also has another gain setting under the Main Menu... Boost... Gain menu item. This gain controls how quickly the controller allows boost to rise to meet the target Channel Boost Gain settings. So if it is set to 100 it will shoot there faster and may spike on the way to the target. Out of the box setting might be 15 while external waste gate applications may need higher settings. I run 100 because... instant boost at the track is additive.
Colder air will result in a higher amount of boost being allowed by the controller at a given gain level. Every lb of boost is probably worth a bit more than .5 a point of A/F on your 60deg nights right now. So if you find yourself 4lbs of boost over your intended 13lbs target for example, there went your A/F ratio. That's where the guys are explaining that a standard MAF tune will not adjust to that missed target level of boost.
So it's important to figure out what is causing the boost spikes and reviewing the controller setting would be a good place to start first.
Rick
Rick
My car was tuned in the winter time in Michigan. It was colder then than it was last night in Tampa, Florida. I guess some missed the part where I said I found a major boost leak right off the turbo? My Boost Controller settings are the same as when the car was delivered.
Channel CH1
Auto/Manu MANU
Set 0
Gain 0
Graph Scale 20
Channel CH2
Auto/Manu MANU
Set 31
Gain 0
Graph Scale 20
Channel CH1
Auto/Manu MANU
Set 0
Gain 0
Graph Scale 20
Channel CH2
Auto/Manu MANU
Set 31
Gain 0
Graph Scale 20
