C6 Rims
Well I myself do not have experience with O.E. C6 wheels. I have factory reproductions which fit better. I also have 18s on all four corners. I'm surprised the guys that do have these wheels havnt chimed in yet. theres quite a few i think.
I would imagine it might handle a little odd. To match the diameter of the rear wheel/tire you need to run a larger profile tire up front. Making the front tires a little softer. I'm not really sure how it would effect handling though.
i had 17's up front and 18's in the rear and just ran a bigger profile tire up front to match the diameter of the rears. didn't notice any bad handling?? now i have 18's all round. just think they look better with the same size
I decided against running the 18's up front and 19's in the rear and I'm in the process of putting everything together to run the 19x10's all the way around w/275/30/19 tires. The tires are now here and I traded (actually sold then bought) the front 18's for a set of rear 19's, so I just need to have evertying mounted and balanced and installed.
However, IF I were going to run the stock C6 18/19 combo, I'd run 255/35/18's on the front and then 275/30/19 or 285/30/19 on the rear.
I have a pair of oem ones with 18 in front and 19 in rear. I used a 1.25 adapter on the rear and didnt have to do any kind of banging or anything else to get hem to fit.
I think they looked good on my car and I got lots of compliments from people on them. I am looking to get rid of them and get something smaller and wider for the rear so I can get dr's on my car for better traction.
After seeing pics of the staggered sizes, I decided I didn't want to go with smaller rims in the front than the rear. The Corvette's wheel wells are smaller in the front to keep the combo looking right, but the F-Body's wheel wells are closer in size and it just looks odd to me to have staggered rims on an F-Body. Since the front 18's are only 8.5" wide, I opted to go with the 19x10's all the way around. Yes I do have to run adapters to make them fit.
Oddly enough, the 18's seem to sell for a little more than the 19's because some guys like to put drag radials on the 18's, but I'm not sure what size DR they use on an 8.5" rim...
michaelg589, you're welcome!
