Any successfull Corsa/LT rasp killers W/O ***s...
Old 01-29-2008, 09:06 PM
99ls1bowtie's Avatar
Default Any successfull Corsa/LT rasp killers W/O ***s...
I just installed Corsa ***back on my SS. I have Pacesetter LTs and ORY and the rasp is killing me. I have read all the threads on corsa rasp and they all are about installing ***s or a bullet. ***s eliminate the rasp..and the bullet helps it. I found one thread where someone installed a powerstick to eliminate it but I can no longer find it. So...can anyone with a powerstick, or anyone with a great method to clean the rasp (besides ***s or inserts) please chime in.
Old 01-29-2008, 09:08 PM
Also...its suppose to say c a t s.....why is it bleeping out c a t s?
Old 01-29-2008, 09:32 PM
TXws6's Avatar
haha thats wierd... cats
Old 01-29-2008, 09:41 PM
cats.....
Old 01-29-2008, 09:42 PM
i guess its working now....anyway...anyone?
Old 01-30-2008, 07:13 PM
anyone???
Old 01-30-2008, 07:14 PM
Masochist's Avatar
Why do you care about rasp if you are so hellbent against using cats? As far as I know, thats the only way to lessen the rasp. You may very well have no choice, my friend.
Old 01-30-2008, 07:36 PM
Tech Resident
ChocoTaco369's Avatar
You can try everything you want from hacking up a $900 exhaust system and adding bullet mufflers, making the merge in the y-pipe better and such, but the simple fact is, nothing will help cut rasp better than a good set of cats.
Get something like a Magnaflow 59959 cat. They'll help cut the rasp and they flow better than any other cat on the market that I know of. That's what I did.
Old 01-30-2008, 07:51 PM
Order 66's Avatar
I would change the y pipe merge. First.
Old 01-30-2008, 08:01 PM
ls2 bait's Avatar
moroso spiral flow is the best one ive had by far. ive changed mine 4 times and that was the best.
Old 01-30-2008, 08:03 PM
slow's Avatar
I hope my APS kit does the trick, my corsa is raspy as hell.
Old 01-30-2008, 10:50 PM
whats the asp kit?
Old 01-30-2008, 11:03 PM
chocotaco, did you have to fab a custom y-pipe? or what did you do?
Old 01-30-2008, 11:09 PM
bigdsz's Avatar
I put an 18" Dynomax bullet in my I-pipe about 5 years, No more rasp or drone.
Old 01-31-2008, 06:13 AM
Marc 85Z28's Avatar
A loose torque converter helps a lot. I leave my cutout partially open by shimming the block-off plate with a couple of washers. ZERO rasp.
Old 01-31-2008, 09:53 AM
Tech Resident
I had a custom y-pipe fabbed up. I don't have much rasp, even with the cutout open, but I'm running cats. The y-pipe isn't the best, either (crush bends), and it goes to show you what a set of cats can do. It's only a temp y-pipe because I eventually wanna go TD's.
Old 01-31-2008, 11:07 AM
Internet Mechanic
BlackScreaminMachine's Avatar
hey man, I have a Corsa with my Dynatech kit, if you were local, id be happy to show you.
With the ORY your going to get ALL noise, what Corsa does is tone down the low end, this saves you from cops and allows you to talk in the car.
I had the ORY with my LT1 383 Camaro, then went to a LS1 T/A 346 and with my new headers I put on some high flow dynatech cats and have had nothing but good luck since.
People used to bust my ***** with the ORY, but now say it sound exotic with the LS1 and cats.
Try not to hack the exhaust up if you can.
Old 01-31-2008, 12:56 PM
vader99's Avatar
I had a corsa with longtubes and magnaflow cats on my car but the glue that holds the catalyst block to the metal enclosure of the cats kept blowing away and then the cats would rattle. After two sets of blown cats I took them out and converted to an ORY. However, the rasp was horrendous without cats and the it was very loud as well. It got to the point that I couldn't stand it anymore so I put a borla xr-1 bullet muffler in the i-pipe and that cured the rasp by 95% and it sounded good. Still was kind of loud so just last year I swapped the corsa muffler out for an SLP dual dual with a DMH electric cutout right before the over-the-axle pipe and now the exhaust is quiet and tame for when I want it and it can also be loud and nasty with the cutout open as well - the best of both worlds.
Old 02-01-2008, 07:05 AM
Internet Mechanic
Ceramic Vs Metallic, there is a huge diff, Metallic F T W
