6.0 Installment On T/a
I need some help on installing a 6.0 on my t/a . Will I need help with the block/motor mounts and will that motor mount up to my transmission without any fabrication. I know all of my electrical parts will work like alternator and everything else .Only potential problem will be to drop the motor in PLEASE SOME ONE HELP ME..........
When I did mine I used the mounts off the LS1, and all the accesories off the LS1. do you have an '03 and newer 6.0? because the older ones have a longer crank which to my knowledge won't work.
