How Many Inches Does A 9in. Rear Lift Your Car?
I don't think that putting in a rearend will raise/lower you car at all (or atleast a noticeable amount). The suspension/spring mounts are all in the same locations. I believe that it will change your driveshaft angle because the pinion is at the bottom of the ring in a 9".
[QUOTE=kozak;8609756]I don't think that putting in a rearend will raise/lower you car at all (or atleast a noticeable amount). The suspension/spring mounts are all in the same locations. QUOTE]
it will raise it some because of the diameter of the axle tubes
