70pontiac tempest LSX swap need insight and advice.
Old 02-03-2008, 03:21 AM
Moderator
91parkave's Avatar
Default 70pontiac tempest LSX swap
hello everyone
This will be first lsx swap i have a 2000^ chevy truck motor and 4l60-e trans that will be dropped in a 70' pontiac tempest. The engine and trans came complete with the wring harness, minus a couple of odds and ends and was wondering besides the mounts and crossmember, if anyone had wiring diagrams for the fuse block and PCM. any additional advise or experience is more than welcome thanks guys.
Old 02-03-2008, 03:33 AM
fenix999's Avatar
good luck, dont think ive ever seen/heard of that swap be4. Cool to see something different Only advice i guess would be to get a complete wiring harness for a hot rod from speartech or painless, but dont listen to me im a noob when it comes to swaps
Old 02-03-2008, 12:03 PM
Moderator
91parkave's Avatar
here some pics of engine and trans with the "harness" are these harnesses easy to wire?
Old 02-03-2008, 05:44 PM
classic gary's Avatar
tempest is the same as a chevelle so look for all the chevelle "A" body swaps, lots of 'em here.
Old 02-03-2008, 07:22 PM
Moderator
91parkave's Avatar
sweet, Thanks guys for the insight, ill be sure to document this build
Old 02-14-2008, 08:00 PM
Moderator
91parkave's Avatar
ok im at a loss here ive been hopelessly searching these forums for a wiring harness.pdf or something, i found a couple on the truck wiring harnees's but cant seem to make sense of the wiring i need to eliminate/modify especially these four plugs, if anyone could help out, id very much appreciate it.
where do these go????
anybody got a truck fuse block diagram?
here some pics i made of the BRP style engine mounts...thank you ls1 FAQ!
random pics
Old 02-14-2008, 08:13 PM
Moderator
JayplaySS's Avatar
Thats gonna be awesome man.
Old 02-15-2008, 12:37 AM
Moderator
91parkave's Avatar
thanks man
Does anyone have any idea what these 4 plugs go to though?? i know 1 of them has to lead to the Electric throttle but the other 3 is what im having problems with finding out, if anyone has any experience with a 5.3 2001 yukon truck harness PLEASE HELP!!!
Old 02-15-2008, 09:22 PM
Moderator
91parkave's Avatar
anybdy? on the 4 plugs? or a diagram of the truck fusebox??
I also polishied up the TB and paint matched it to the car
Old 02-15-2008, 11:12 PM
BoozrCruzr's Avatar
The top grey colored plug goes to the Throttle Actuator Contoller (drive by wire module). Off the top of my head, I think the other 2 big connectors go off to the body control module. Not sure on that one.
Chad-
Old 02-15-2008, 11:24 PM
bczee's Avatar
Can't help much on the wiring for the truck harness.. I just had to ping in and say great project to do.. If you have any question as far as a A-Body.. ask away and I'll answer if I can.. Have fun..!
Old 02-15-2008, 11:55 PM
Moderator
91parkave's Avatar
Chad-
cool thanks i finally got a hold of the harness pinouts and verified, so now its time to start trimming, thanks for the input, i need to pick up that damned module and harness when i get a chance...
actually yea, did you use a 1/4 spacer under the cradle mounts as well? other than that what do people use for the speed sensor inputs? im a little puzzled by this next obstacle but thanks for the input always appreciated
Old 02-16-2008, 12:24 AM
sawzall wielding director
G-Body's Avatar
Is that really a 2001 yukon motor? I thought the 01`s still had cable TB`s.
Anyway the VSS signal...well if your not using a late model trans you will probably end up with something from jags that run. You need a sine wave AC input. They have senders that screw inline with your speedo cable, or you can mount one on the pinion of the rear end.
Old 02-16-2008, 01:08 AM
Drew04GTO's Avatar
Kinda OT but do you have any more info on this, I need a 5v occilator like this to fool a toyota v8 ecu so it'll go over 2000 rpm and I'm having a hard time finding a PCB/kit to do it.
Old 02-16-2008, 01:41 AM
G-Body's Avatar
I don`t know of any PCB`s/kits to fool the PCM, but how about putting an actual VSS on? I have heard that you can pick them up a some speedo shops(they are sometimes used as an add-on in cabs to run the fare meter) Or check at jags that run as they sell a lot of different VSS`s and should have something for your application.
Old 02-16-2008, 10:01 AM
Moderator
91parkave's Avatar
ay ill be us 4l60-e, so it has the VSS already?? also im figuring out this iring harness but the fuse box puzzles me i cant figure out where the hell i hook up my batt+ and ignition to
Old 02-16-2008, 11:25 AM
72ChevelleConv.LS1's Avatar
Guess how fast you go! No need for a speedo! In the end, you only need a few fuse. the coils need 12V the injectors need 12V the PCM needs 12V and maby one more thing. You sure have a lot of fuses.
Old 02-16-2008, 12:27 PM
Moderator
91parkave's Avatar
.....tell me about it.. Ok so all injectors to a 12v all the coils to a 12v, and the PCM to a 12 v, ign,? I think i can manage that, i was just wondering how to do it using the factory fuse block i found a thread on some guy named jeepster who used the fuseblock but it confuses the **** outta me..
Old 02-16-2008, 07:52 PM
Moderator
91parkave's Avatar
I said **** the haoday so i test fitted the engine and decided....since im on a extreme budget, that i'd go with hacking a inch into the cross member so the oil pan would clear, took me about 30 minutes of cutting with a angle grinder and grinding it out a little, tommorow ill weld a plate in, to help out the strength and fab my cross member...almost there baby!
Old 02-29-2008, 12:46 PM
Moderator
91parkave's Avatar
Updates!
motor sittin at 2 degrees!!!! still messing with the fusebox idea preety soon im just going to stand alone if i cant figure out how to use it how i want to, Thanks to everyone though for their help on here ill be sure and keep yall updated!
Impala gas tank test fit:
seems my Park Ave tire is the perfect spacer!!lol
DBW pedal hacked up and welded back
sooner or later i will need a cts oil pan but the truck will have to do for now!
And the harness getting raped
Tried to trace the ignition SW maxi fuse to the bottom of the fuse box but kept getting multiple outputs instead of the im looking for
Quick Reply: 70pontiac tempest LSX swap need insight and advice.
