help me... procharger project
Old 02-05-2008, 09:20 PM
1Cammed98Z's Avatar
Default help me... procharger project
i came across a really good deal on a complete set up off a marauder. i want it for the unit and intercooler mainly.. but can you help me out and let me know if i can use anything else and what the biggest problems will be that ill run into. thanks
Old 02-05-2008, 09:24 PM
kwiksilverz28's Avatar
What kind of car, what kind of supercharger. Details!
Old 02-05-2008, 09:29 PM
1Cammed98Z's Avatar
i have a 98 z28 and believe a d1sc im goin to find out more info on it tomorrow.
Old 02-06-2008, 12:25 AM
01bad ss's Avatar
Head unit needs to be a reverse rotation to mount to the brackets you will buy for the procharger if it is a d1sc.If it is RR and you can possibly use the head unit and maybe the intercooler,you will have to buy a crank pulley,head unit pullies,brackets and tensioner,belt ,piping and bypass or blow off valve.Tried to piece together a set up myself but found it is easier to buy a kit.
Old 02-06-2008, 05:20 AM
EPP
EPP's Avatar
This chart will help you out. Bob
http://www.exoticperformanceplus.com...html?item=1227
Old 02-06-2008, 07:22 AM
8 sec potential, 12 sec slip
ChevyChad's Avatar
As mentioned above, make sure it is reverse rotation. Don't forget the shroud and fan too to make it a complete kit...
Old 02-06-2008, 07:21 PM
1Cammed98Z's Avatar
has any of you heard of mounting it where my ac pump was. i seen some pics where a guy installed it over there but i couldnt get ahold of him. and he had pics of the procharger bracket next to the stock ac pump bracket and they were indetical except for the fact the stock one had the tensioner pulley on it. and if i did that would i be able to run the belt on the same track as the stock belt went on the outside of the crank pulley. thanks
Old 02-06-2008, 10:16 PM
ChevyChad's Avatar
Well, the stock A/C belt is like 4 rib IIRC. Definitely a no go. If you did mount it over there (if it will even in fact fit), you'd still need to run a dedicated pulley in front of the accessory pulley like the f-body kits do. And I'm pretty sure you could NOT use the A/C compressor bracket to mount a procharger.
Old 02-07-2008, 12:11 AM
1Cammed98Z's Avatar
alright.. like i said im new to the whole superchargin thing and tryin to learn every little thing i can before i make any mistakes... thanks for all the input
