Major radiator poblem
Friend of mine has a '01 V6 Firebird. About 2 months ago his temp gauge wouldn't even raise when the car was warmed up, it was stuck. He had it flushed and the problem went away for 2 weeks, now it is again not raising past the start point. He flushed again and snaked it to see if there was a clog. Again after 2 or 3 weeks of working fine and raising to operating temps, it is stuck . Is there an air pocket or clog??? Anyone have this problem??
It's most likely gonna be the thermastat. The fact that the heater is only getting warm and not hot is a definitely pointing to that. If it was a faulty Temp sensor, gauge, radiator, or water pump the car wouldn't fail to heat up properly. The thermastat hanging open is the only thing that will cause that.
guys he changed the thermo and so far so good! again though he had everything working right after fluid flush and the problem took 2 weeks to come back so he is hesitant to celebrate until he passes that spot. I believe in your advice though and appreciate the help!!
