LT1 to LS1 swap...how hard?
Old 02-07-2008, 08:31 PM
GreatWhiteZ28's Avatar
Default LT1 to LS1 swap...how hard?
just wondering how hard it is to do an LT1 to LS1 swap...Know i need a LS1 wiring harness and PCM, and the K memebers have to changed out...just curious as to how big of a PITA it is
Old 02-07-2008, 08:33 PM
deadlyz28's Avatar
its unpossible
Old 02-07-2008, 10:48 PM
TT-TECH Veteran
Inspector12's Avatar
Contact Joe ex-SS-ve. Here is a post he started its not that hard.
https://ls1tech.com/forums/texas-members/859587-fri-nite-2-8-08-a.html
Old 02-07-2008, 11:35 PM
Blue's_Z28's Avatar
God yeah, Joe's car...
Old 02-08-2008, 01:31 AM
Mike96z's Avatar
EASY if you have the parts and the money.
Old 02-08-2008, 03:39 AM
streetassasin's Avatar
R.I.P. LT-1
Old 02-08-2008, 08:16 AM
Mike96z's Avatar
Ive actually finished mine besides the fact I just had to order a LS1 clutch pedal setup.
Old 02-08-2008, 12:21 PM
ckyconan2003's Avatar
i think its a very smooth transition if you have a 97 car. get the Ls1 and T56, wiring harness, ls1 k member. and clutch setup. Prolly need a new radiator and condensor if you wanna do it right. there are about 3-4 guys on the forum who have done it. i wish i would've done it to my 96 but thats another story and now i have a 97!
Old 02-08-2008, 12:35 PM
ArchOverseer's Avatar
Originally Posted by streetassasin
R.I.P. LT-1
It's not dead....He found the problem and it's fixed.
Old 02-08-2008, 12:38 PM
It was a very easy fix Sreet........but yeah back to the swap questions, I won't be going M6, more likely a TH350
Old 02-08-2008, 01:17 PM
congrats man what was it? And we need to find a time to get that vid before the H/C LS1 goes in sorry for the
Old 02-08-2008, 01:35 PM
Mike96z's Avatar
use the LT1 radiator, block off the one hole at the bottom of the driverside, LT1 radiator was sold as an SLP upgrade for the LS1. Can use LT1 condensor too.
Old 02-08-2008, 06:27 PM
Condenser is gone, car has no A/C and will never have it agian prolly, I need a new radiator anyway so thanks for that bit of help as it eliminates some head scracthing
Old 02-08-2008, 07:38 PM
blackesteyes8696's Avatar
i'm currently doing this swap right now and i lucked out by having a complete 98 TA donor car. But the tranny was shot so i had to buy a special flex plate to adapt my LT1 tranny to the LS1 block. So far its nickled and dimed my *** to the ground but alot of it was precautionary BS that i weanted to eliminate down the road. plugs, wires,main seal, motor mounts, painting the engine bay, etc..... good luck! wiring is gonna be fun
Old 02-10-2008, 07:36 PM
Awp944's Avatar
I am curious about this swap as well...I have a 94 Z28 the motor is pulled out from the bottom..I blew it up and i was just wondering what do I need for the swap besides the motor,wiring harness,computer,subframe...Its an auto
Old 10-21-2008, 09:27 AM
paul burkhart's Avatar
where did you get the flex plate?
Old 10-21-2008, 06:05 PM
93z28joel's Avatar
I am thinking about doing a ls6 swap this winter. does any one know a good link where i can get some needed info... I have been looking and cant find anything good.
Old 10-21-2008, 11:07 PM
5.3LJimmy's Avatar
This site http://www.dxsoftware.com/magnus/ has detailed instructions and pictures. Just do a search for "lt1/ls1 swap" using the advanced search feature and selecting the conversion forum. I promise you all the info you need will be there.
Old 11-08-2008, 04:23 PM
95/02ss's Avatar
I am looking at doing the same thing.I checked your link and all I got was v-6 conversion....
Old 11-08-2008, 05:25 PM
the_merv's Avatar
Not too hard to do, Wiring is pretty easy..
Don't touch ANYTHING with the Wiring on the Fuel Guage, that's on a different Circuit. Most people have a mis-conception about that.
Here is my swap..
1995 CAMARO -> 402 STROKER
Quick Reply: LT1 to LS1 swap...how hard?
