5.3 or ls6 with torquer v3
i have searched and have not been able to come up with good evidence to go either way. should i get 5.3's or ls6' to run with a torquer v3? either way they are going to be ported, and if i get the 5.3's i will probably be swapping the valves from the ls6 heads into them.
They are both good heads and proven performers but if I was you and had both sets I would put the LS6 on. The combustion chamber on the LS6's are what makes them and the D shaped exhaust ports. The only advantage I would see in the 5.3 is compression that I know of but Ive never put 5.3 on LS motors in a car.
