pics of my sdce 8 rib setup!!!
Old 02-12-2008, 12:46 AM
Restricted User
eastoaklandss's Avatar
Default pics of my sdce 8 rib setup!!!
i installed this kit about 3 months ago! i love the kit and have had zero problems with it. the people at sd concepts were very helpful and answered all my questions and concerns. i even got the belt perfectly aligned the first time!
Old 02-12-2008, 02:53 PM
aznspeed's Avatar
Thumbs up
Looks nice and clean.
Old 02-12-2008, 03:01 PM
TT-TECH Veteran
Inspector12's Avatar
Looks good! I would definately be working on a real air filter for it. It took me about 3 hrs to make my own from stuff I picked up at Pep Boys LOL! A guy Mark from Louisiana helped me with his photos he posted etc... I am using 4" aluminum pipe with a filter works good required a little trimming of the core support though.
Old 02-12-2008, 03:44 PM
618HAWK's Avatar
How close dose the crank pulley run to the idler pulley, sure looks close.
I guess there is no room for a larger crank pulley, 7-5/8 would be out of the question???
But than again with no slippage, I guess you could pulley down on the blower side, to make up for it????
What crank pulley are you running?????
Old 02-12-2008, 04:01 PM
Z06PSI's Avatar
The alternator? It is gone down below. I like that. Going to have to see if I can do that. It just looks so ugly on the top side.
Old 02-12-2008, 04:02 PM
Z06PSI's Avatar
Is that a stock F-body mount for the alternator?
Old 02-12-2008, 04:20 PM
frcefed98's Avatar
yes, the alternator on a F body is on the bottom driverside.
Old 02-12-2008, 08:23 PM
Subliminal Hit's Avatar
Since your making some decent power and have a good penny in your engine, I would quit running that $2 fram filter and run something with a synthetic element like a mobil 1 or k&n. I read a lot about those fram filters coming apart.
Old 02-12-2008, 09:38 PM
TT-TECH Veteran
What filter are you talking about all I see is the screen in front that only keeps small animals out? Never mind I see you were talking about the oil filter.
Old 02-13-2008, 12:51 AM
Restricted User
i used to only use k&n oil filters but stopped caring because i didnt think they really did that much of a better job.
Old 02-14-2008, 01:25 PM
bearcatt's Avatar
Nice job!
That's an interesting SDCE/Custom setup you have there.
Different than your typical ATI D1SC.
Looking at your pictures, it appears you did some motor work too.
That's a nice ride you have there.
Old 02-15-2008, 10:37 AM
Restricted User
Originally Posted by bearcatt
Nice job!
yeah my sig tell its all!
Old 02-15-2008, 11:01 AM
30th t/a's Avatar
looks awesome!
So are you making all that power on just a single racetronix pump??
Old 02-15-2008, 01:51 PM
DeltaT's Avatar
Looks good, but you are going to need to change out that screen pretty quickly to a heavier stainless mesh. That screen will flex back and forth as you rev and shift and break pretty quickly and you know where it is going to goe first...
Jim
Old 02-15-2008, 04:51 PM
No Juice's Avatar
Do I see an extra brace going from the oil pan bolt to the blower bracket?
Please explain???
Old 02-15-2008, 05:52 PM
kp
kp's Avatar
Please explain???
Its a little brace that comes with the SDCE kit, not really sure how much it helps. Sometimes I use it, sometimes I dont and havent really noticed any difference either way. But if its there why not use it..
Old 02-15-2008, 06:01 PM
ADCTD2BOOST's Avatar
whats the price difference between the one you have and the 8 rib procharger sells?? reason i ask is because i am going to be doing an 8 rib set up and i need the best proformance.
Old 02-16-2008, 05:13 AM
DanaliHD's Avatar
lookin good. i'm probably gonna drive down there this summer and have scott look at making some form of 8 rib setup for my KB when I get it back from W2W
Old 02-16-2008, 06:27 AM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
I am surprised you are still running the power steering cooler. I had to take mine off because it was rattling on top of the tensioner.
Old 02-17-2008, 02:33 PM
Restricted User
Originally Posted by 30th t/a
looks awesome!
yes i am but its pretty much maxed out now.
Quick Reply: pics of my sdce 8 rib setup!!!
