Turbo longevity
Old 02-12-2008, 11:53 PM
code4's Avatar
Default Turbo longevity
I took my turbo off tonight to put on an ATI pulley and noticed that there is quite a bit of play on the turbo shaft.
It is a tc76 with around 5k miles. I have read that end play is normal but I can pull it to the side until the tubine blades almost rub the housing.
I wonder if I should send it in to be on the safe side? How often should a turbo be rebuilt under heavy duty use.
Old 02-13-2008, 01:09 AM
nz12's's Avatar
yup it's prob about due. What is you oil system and what kind of oil????
Old 02-13-2008, 07:47 AM
52172's Avatar
I would think you would get much more miles than what you have on yours out of it.
Old 02-13-2008, 08:58 AM
code4's Avatar
Just a normal feed & return line. I have been using royal purple 10w 30.
I will try to call Jose today & see what he thinks.
Old 02-13-2008, 09:32 AM
52172's Avatar
I've never heard anything good about royal purple??
Old 02-13-2008, 01:03 PM
kbracing96's Avatar
Your turbo's probable fine. You have it backwards, there should be almost no end play, but side to side play is very necessary in a journal bearing turbo. .018 to .022 (which feels like a LOT) is considered with in tolerance in most turbos.
Old 02-13-2008, 02:18 PM
code4's Avatar
Yes I understand I just used a bad choice of words. There is no end play just side to side. I wish there was a way that I could measure or check the turbo to know if it's within specs. I hate for it to go bad in the middle of summer, they're too short as it is.
Old 02-13-2008, 05:33 PM
kbracing96's Avatar
A match book cover is about .015 if that helps you gauge it. What your doing with is hardly considered heavy duty use. These same type turbos run on diesels at 20+ psi and last 100k+ miles. If it's not hitting the housing, you should be fine.
My old T-60 is on another truck now and has probable 50K on it now, and still going strong.
Old 02-13-2008, 07:11 PM
code4's Avatar
Cool, thanks. I'll go out & see how much clearance I have with a feeler gauge.
I'll prob put it back on tonight.
Old 02-13-2008, 07:39 PM
Dragframe's Avatar
Turbos on the semi's generally start failing at 250k. Some last much longer.
Only time they really fail with anything lower on em is a freak accident. Uncommon.
Quick Reply: Turbo longevity
