Replace cat with cut-out, or leave cat?
I'm going to get a cut-out, but I was wondering is it to raspy to replace the cat with a cutout, or should I just put the cut-out after the cat? I tried searching couldn't really find what I was looking for.
Does it make it raspy and backfire and pop? I really do not like that sound it drives me nuts and it sounds like absolute sh*t! Anybody have a sound clip with stock headers with a cutout and no cat?
I just have the cat taken out. I machined a tapered piece to fit into my Cat back flared end pipe end. I then welded the piece to a plate that I drilled and tapped for the stock two bolts to fit on the bracket to hold the pipes together (and to mount to the car). The plate mimicked the plate at the end of the cat.
I take one bolt out and loosen the other and let the exhaust hang below the y pipe at the track. The car in my opinion sounds good and dosen't pop unless I'm deaccelerating hard.
Are you gonna use the cut out on the street? Then I might consider a cut out, other wise I don't know why you would.
Yes I plan on using the cutout on the street. That's the whole reason I want it. I really want a sound clip of stock headers with a cutout. Also I want a sound clip of exhaust with no cat or headers. I have 2OTL so without a cat will this be raspy and pop?
