HELP? how to check engine compression ?
anybody knows how to check the engine compression im try'n to check what compression will this engine combo will be at :
6.0 block with 4.000 std. bore
wiseco pistons with -11cc 4.000 bore
3.622 oem crank
6.0 317 heads oem not ported at all 71.2cc
with oem 6.0l head gaskets
scat I beam rods 6.125
so if anybody can check please if any body knows im trying to get the compression at 8.8:1 to 9.4 but i want 9to1 compression thanks for the help.
THIS WILL GO IN A turbocharged engine..................
3.622 oem crank
i checked in a calculator but i got 9.1 compression but i dont know if im doing it wrong can somebody check for me and let me know the engine parts im going to use are up their on top thanks ..................>>>>>>>>>>>>>>>>>
Calculator suggests around 9.1:1 c/r.....10 psi high octane....dont risk it.....Any higher
Use water meth/boost cooler and keep it reliable.....
Dont go to insane with the timing.....More power also means more boooooooooom!!!!!!!
A thicker mls headgasket will lower your c/r...as well.....ahaaaaa
Did you think of that?I dropped a whole point in my tt project car./....
