View Poll Results: Which cats should I go with or none?
Buy some stock cats.
4
10.00%
Buy magnaflow cats.
14
35.00%
Run em w/o cats.
22
55.00%
Voters: 40. You may not vote on this poll
Catalytic converters question.
I'm going with an x-pipe an moroso spiral flows. Wasn't planning on running cats but now I think I will. I was told about these stops where they check if your car passes emission and now these breathilizer for the exhaust which check if your car has cats and if they work. I need some stock cats if anyone has any that work let me know. if not what kind of cats are good and not too expensive. What size are stock cat pipe?
well ur screwed anyways if you change the cats or change stock location..plus the breatherlizer you mean like something they put up close to yur pipe or the ones on the onramps??
plus they see a dumped system it wont pass either im guessen
I'm doing it so if they stop and check if too much emmisions are coming out then there won't be. It won't be getting dumped going under the axel. Oh I know a place that doesn't care about visual inspection.
Just get something 300 square with a metallic core... I just bought these:
Detailed Description
Thunderbolt cat's are designed to give high performance in limited spaces. This high flow converter features a Metallic brick with 300 holes per square inch. This 100% EPA legal OBDII catalytic converter is designed for engine's up to 5.9L / 6000 lbs. (Not for use in California)
Part # - 415300
Length - 11"
Body - 4" Round
Inlet - 3"
Outlet - 3"
Brick Type - Metallic
Material - 409 Stainless Steel
for $55 each Non-sponsor so don't ask for a link but I gave you plenty of info to search off of...
Part # - 415300
Length - 11"
Body - 4" Round
Inlet - 3"
Outlet - 3"
Its not worth it in Cali dude. Some high flow cats are not going to kill your HP. I know people that have been caught, its an expensive mess and cops are looking for loud cars with no cats. Its a big fine.
Part # - 415300
Length - 11"
Body - 4" Round
Inlet - 3"
Outlet - 3"
Part # - 415300
Length - 11"
Body - 4" Round
Inlet - 3"
Outlet - 3"
ive been pushing these since i put them on last year. and they fit great
Why do you guys run illegally like that? I mean, do you go rob a bank when you need money because you dont care about the law?
The damn tree-huggers in this state have made it so you could get your car impounded if you're stopped by a cop. Its not worth the risk to me. And I dont see why you guys would risk it too, all for at most 5 horsepower. Not to mention the loudness is a genuine cop magnet.
Plus, the more people who get caught without cats and other smog equipment, the more fuel that gives the tree-huggers to write even tougher laws. Eventually even SEMA wont be able to stop them and it'll be illegal to make any change to our cars.
[/gloom and doom]
[/gloom and doom]
[/gloom and doom]
[/gloom and doom]
I know. I'm about to delete this ******* thread!
