Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
What kinda HP should this setup make?
Old 02-18-2008, 11:27 AM
Chevy_Stroke's Avatar
Default What kinda HP should this setup make?
388 stroker
Eagle crank & rods. .60 Over
Keith Black Pistons 10.5 -1 comp. MSD Dist
Roller Rockers, Wieand Intake. Holly Carb,
400 heads with 1.94 1.60 valves, ARP Bolts
COMP CAMS CAM Specs Below
Basic Operating RPM Range: 2,500-6,500
Advertised Duration: 292 int./292 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.501 int./0.501 exh. lift
Lobe Separation (degrees): 110
Grind Number: CS 292H-10
@ flywheel?
Old 02-18-2008, 11:54 AM
moge11's Avatar
320 maybe 335-340 tops.
Old 02-18-2008, 12:04 PM
dodgn bullets's Avatar
Off the top of my head I was thinking somewhere around 350. Maybe a little less. Is this what you are thinkin about runnin or do you already have the set up?
Old 02-18-2008, 12:12 PM
all ready have it and looking to sell its a fresh rebuild.
what do you thing i could ask for it?
Old 02-18-2008, 12:43 PM
Not really sure. How much do you have in it? I know you probably won't get that out of it but it's a good place to start.
Old 02-18-2008, 02:27 PM
maybe $700
Old 02-18-2008, 03:29 PM
1994Z28Lt1's Avatar
i dont see any reason why that engine shouldn't be making closer to 400 horse
Old 02-18-2008, 03:53 PM
thats what i thought.
Old 02-18-2008, 04:00 PM
7 Second Club / STF Veteran
68maro's Avatar
the heads are junk thats whats killing the motor
Old 02-18-2008, 04:33 PM
what kinda heads should i use that wont cost ton?
Old 02-18-2008, 04:56 PM
1994Z28Lt1's Avatar
depends on what CC the heads you have on there, but you could pick up some vortec heads cheap <600 but they have 64 CC chambers so it depends how your compression would sit afterwords
there are tons of better flowing aftermarket head for a lot more money though
Old 02-18-2008, 09:51 PM
If you are looking to sell it, why would you put different heads on it. Are you looking to drop it in something if you can put down better numbers?
Old 02-19-2008, 06:05 AM
If I can make it make decent power cheap ill keep it.
Old 02-19-2008, 09:04 AM
jmm98LS1's Avatar
Depends on what "cheap" is to you I guess. A set of budget vortec heads would really wake that motor up and push you well past 400hp.....BUT---Most of the 400 heads had 76cc chambers IIRC. If you're already at 10.5:1 static compression with them, your compression would shoot into race gas territory with vortec heads since they're 64cc. Define "cheap" and you'll get some suggestions on what you can afford.
Old 02-19-2008, 03:29 PM
prolly $700-$900
Old 02-19-2008, 10:06 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Agreed that the heads are going to the major limiting factor on HP production on that motor. Also what exact intake and carb are you running?
Old 02-20-2008, 06:28 AM
Weiand 7546 X-CELerator
when i get new heads im goin with a air gap.
