What should a Stock 00 SS Idle at????
Old 02-18-2008, 04:24 PM
djfury05's Avatar
Default What should a Stock 00 SS Idle at????
hey all, I just have a question about idling. My 00 SS idles at 500rpm after warm up. Is this normal?? Seems pretty low to be idling around there I guess. I believe this car is completely stock as far as my knowledge spans, but maybe theres a cam?? Please help and give any suggestions on what I should do. The car as it sits has an air lid that's it.
Old 02-18-2008, 05:12 PM
2001NBMZ28's Avatar
If you have an A4 and that's in gear with your foot on the brake sounds about right. My tach read just over 500 and fluctuating 525-585 on a scanner with the stock tune.
Old 02-18-2008, 10:56 PM
ae13291's Avatar
M6 should be at 700rpm and A4 at 600rpm
Old 02-18-2008, 11:38 PM
SladeX's Avatar
The m6 actually idles higher. I think my stock was 800rpm and after the cam I had to raise it to 900rpm.
My tach is a pain in the ***, it shows 1000rpm regardless for my idle. Pre and post cam tune.
The auto is 600rpm.
Old 02-19-2008, 04:32 PM
ino
ino's Avatar
Mine idles at 500 or a bit above at stoplights.
Old 02-19-2008, 08:34 PM
Flawless02SS's Avatar
Mine was around 750-800 when it was stock.
Old 02-19-2008, 10:37 PM
SladeX's Avatar
The stock tach is very inaccurate. Not only that, it also lags behind a good amount as well. For my car it's off by 200 rpm when climbing in rpm.
With a 900 idle, it's showing 1000rpm.
From the responses on this thread, it just shows you the variance in the tachs.
Old 02-19-2008, 10:50 PM
HoLLo's Avatar
The tach shows I idle around 1000rpm and sometimes 1200
Old 02-20-2008, 11:07 AM
qwk93ta's Avatar
My stock A4 00 WS6 idles just a little above 500 at a stop light.
Old 02-21-2008, 10:09 AM
Quick99TransAm's Avatar
Default idle
My 99 a4 T/A idles like that at stop in gear or out of gear always thought it was weird friends cars always idled close to 1000 or 900 i have a hand held scanner but know i guess it is normal
Old 03-26-2008, 06:08 PM
firechicken76's Avatar
mine idles at 1500 when cold, then after about 30 sec drops to 1000, then when warm down to 700 or 800 is that normal?
Old 03-26-2008, 06:21 PM
binks0678's Avatar
my m6 idles at 800 when warm...at least thats what my tach tells me
