Cruise, VSS, electronic throttle question
Old 02-19-2008, 06:51 PM
BoozrCruzr's Avatar
Default Cruise, VSS, electronic throttle question
Looking for an answer on this one, and it seems to have most people I have talked to stumped. I am running a 5.3 w/ electronic throttle in a 79 Jeep. The trans is a Th400 and there is a transfer case as well. The speedometer drive is a cable coming from the back of the transfer case. I want to retain the cruise control. I know I will need a VSS and this is where the question is.
I have found a 20 pulse per rev VSS that will hook onto the speedometer cable. Will this be sufficient for the cruise to work? I think this will put the pulse per mile at about 20K. The trans functions in the PCM will be turned off since I am using a TH400. Is there anything else that needs to be considered in the programming?
Thanks guys!
Old 02-19-2008, 08:15 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Mind sharing where you found the vss adapter? Does it go where to two speedo cable would go on your TH400?
Andrew
Old 02-20-2008, 12:35 PM
BoozrCruzr's Avatar
VSS is from: http://www.speedometersolutions.com/
Anyone got any ideas about my question?
Thanks in advance!
Old 02-20-2008, 12:42 PM
merriman44's Avatar
Abbott makes a good vss adapter as well. Not that that answers your question
Old 02-20-2008, 08:08 PM
LS1MCSS's Avatar
You will just have to reprogram the pcm for the 20ppr vss. The vss does put out a sine wave signal, doesn't it?
Old 02-20-2008, 09:54 PM
BoozrCruzr's Avatar
Yes, the sensor puts out a sine wave. The only problem I see is this. From my calculations, the driveshaft turns 2.5 times for the speedometer to turn 1 turn (still have to test this). This would mean you'd need to program the ECM for 8 (20/2.5) pulse per rev and divide your calculated pulse per mile by 2.5 as well. Does that make sense? Am I out of my mind?
Old 02-21-2008, 06:33 AM
LS1MCSS's Avatar
The programming will be for driveshaft revolutions. The T400 is direct drive in third, so I don't understand what you are talking about on the 2.5 turns. You will need to program for a 20 ppr vss. What is the p/n of the vss? I am making some changes to my setup and will need a different one.
Old 02-21-2008, 05:54 PM
BoozrCruzr's Avatar
They never gave me a part number, they just said they had one. Shoot them an e-mail, they respond pretty quick.
Here's my math:
The driveshaft turns 2.5 times for the speedometer cable to turn 1 time. So, if the sensor is mounted on the cable, it is really turning 2.5 times slower than the drive shaft. So, 20 is really 8. Pulses per mile would be the same thing.
Old 02-22-2008, 09:32 PM
65SSZO6's Avatar
You two are making my head hurt! See if this helps...http://www.jagsthatrun.com/V8-chapte...ed-Sensors.pdf
Old 02-23-2008, 03:58 AM
blazerboy72's Avatar
I am using the same combo (5.3/th400). On mine I ordered the pass through pulse generator from summit. It allows you to keep your cable driven speedo and have vss. I didnt need the cable driven part so it is blocked off on mine. To correct the ppm I also ordered a speedometer reccalibrater from dakota digital. It has multiply outputs so it should have what you need to run cruise. On mine the toyota gauge and cruise require differnet ppm's so it made it easy for me but if you are using a cable driven speedo you wouldnt have that problem.
Old 02-23-2008, 06:22 AM
LS1MCSS's Avatar
OK, I see what you mean now. Because of the factory speedo gears, you won't get one cable turn per drive shaft revolution. Since a T56 or an A4 are getting 17 and 40 pulses, respectivly, per drive shaft rev, then your math would be correct.
Old 02-23-2008, 10:02 AM
schwoch1's Avatar
Did you ever think of mounting a 40 tooth gear of some sort on the output shaft of the transmission/transfer case. I know that the Dodge 2.2/2.5 ( ) upper timing belt gears are 40 teeth and could be rigged up in some fashion to work on a driveshaft yoke. Cheap and effective, you could trim some of the gear away 'cause all of it is not needed for the sensor to read on !
Mike
Old 02-23-2008, 02:34 PM
LS1MCSS's Avatar
JTR has a 40 tooth setup that bolts to the front yoke of a 7.5 or 7.625 GM rear end. It uses a chevy VSS thats actually made for a transfer case on a 4WD.
Old 02-23-2008, 04:59 PM
BoozrCruzr's Avatar
Mike
Hmm...wonder where you got that idea from? I'm sure who ever gave you that idea must be an engineering GENIUS! I bet it would turn out something like this:
I call that a 40 ppr reluctor ring!
Old 02-23-2008, 06:00 PM
schwoch1's Avatar
That is exactly what I was thinking. Looks pretty good!
Mike
Old 02-24-2008, 07:06 AM
LS1MCSS's Avatar
Now all you need is a mounting bracket and VSS, gm p/n 1554752, and you're set. The VSS is used on the transfer cases of 1989 and newer S-10 4x4 trucks, AWD Astro Vans, and
1987 and newer full-size 4x4 trucks.
Quick Reply: Cruise, VSS, electronic throttle question
