Western Members CA, AZ, NV, UT, CO, NM, HI
wanted: 95 camaro Z28 fuel pump
Old 02-21-2008, 07:30 PM
59 camaro's Avatar
Default wanted: 95 camaro Z28 fuel pump
im looking for a 95 camaro fuel pump....let me kno what u have...hit me up or send me a pm on here....call me at 323 718 0512
Old 02-21-2008, 07:45 PM
ssbowtie1's Avatar
Best bet is go for for the racetronix fuel pump kit. Its a direct replacement.
Old 02-21-2008, 07:51 PM
59 camaro's Avatar
where can i get that fuel pump at?....i dont really kno much about these LT1's...thanks
Old 02-21-2008, 07:56 PM
ssbowtie1's Avatar
http://www.racetronix.com/RX-FLT1-FPKG-2.html
I installed this pump a few months ago. I've been hearing of alot of lt1s needing fuel pumps lately. Maybe its the ethanol in our gas.
I used the trap door method also fwiw. If you need info do a search, there are even some how to's floating around.
Old 02-21-2008, 10:57 PM
59 camaro's Avatar
hey the car is going to stay pretty much stock, do u think i should go with something less performance wise?.....i found some on ebay for a lil chaper...i kno that my LS1 had the pump in the back...does the lt1 have it in the gas tank too?
Old 02-22-2008, 10:01 PM
59 camaro's Avatar
ttt...
Old 02-22-2008, 10:14 PM
ssbowtie1's Avatar
How much cheaper are you talking? The best thing about this kit is its directly plug and play. Other kits will require you to potentially have to remove the fuel pump bucket that it sits in and do other modifications. IMO, even if the car will stay stock, this kit is definitely worth it.
The fuel pump is in the back, inside the fuel tank.
http://www.geocities.com/formulapower2/fuelpump.html
Old 02-22-2008, 10:18 PM
59 camaro's Avatar
so this racetronix pump mounts in the back like the oem?....
Old 02-22-2008, 10:21 PM
ssbowtie1's Avatar
Yup, check out the writeup.
Old 02-22-2008, 11:30 PM
EkS
EkS's Avatar
If you're staying stock, stick with a stock pump. Or you can just buy the Walbro pump itself without the harness. All that is over kill on a stock car, you won't see any HP gains.
I have just the Walbro pump in my LT1 car.
Old 02-22-2008, 11:34 PM
ssbowtie1's Avatar
If you feel like fabbing up your harness go right ahead. Nothing is "overkill" on that kit, in fact the pump is a Walbro pump. Its just a question of do you feel like scrounging up all the parts and fabricating parts to fit the pump in, or do you want a plug and play kit.
Old 02-23-2008, 01:01 AM
EkS
EkS's Avatar
Fabbing up a harness?! If there is something different on a b-body than a f-body no need to fab anything up, just plug and play. The harness they sell is to get more voltage/cureent to the pump. His car is stock, no need for any of that. Just get a Walbro pump and call it a day, unless this is the beginning of more mods to come.
Old 02-23-2008, 02:04 AM
ssbowtie1's Avatar
I'm not telling him to get the electrical harness. Lets make this visual:
VS.
Both walbro pumps. One is plug and play, one is not.
Quick Reply: wanted: 95 camaro Z28 fuel pump
