p1sc-1 questions
I think the most I have seen was 15psi on a 347.I dont recall the pully size but if you want to go tha high I would go with a D1sc.because it seems to me it would be less taxing on the s/c.
How much boost the blower can produce depends on many variables, so it is hard to predict how much boost you are going to see.
* Cubic inch. The larger the engine the less boost it will make with a P-1SC.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
Bob
Bob
Bob
