p1sc-1 questions
Old Feb 21, 2008 | 09:30 PM
mycar2fast's Avatar
Default p1sc-1 questions
anyone know how much boost you can squeeze out of a p1sc-1 procharger??????
Old Feb 21, 2008 | 09:53 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I made 14psi on my previous setup on a forged 347. This was with a 7.65/3.4 8-rib pulley combo at 6500 RPM.
Old Feb 21, 2008 | 10:04 PM
LT1_Fireman's Avatar
I think the most I have seen was 15psi on a 347.I dont recall the pully size but if you want to go tha high I would go with a D1sc.because it seems to me it would be less taxing on the s/c.
Old Feb 21, 2008 | 10:58 PM
ChevyChad's Avatar
That is very true. A D1 is just getting to be in the sweet spot at 15 psi where as a P1 is running out of breath at the same point.
Old Feb 22, 2008 | 01:05 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
I saw 13 on my former P1SC. With the 7.25 crank pulley and the 3.4 sc pulley. Don't remember the rpms.
Old Feb 22, 2008 | 04:54 AM
EPP's Avatar
EPP
How much boost the blower can produce depends on many variables, so it is hard to predict how much boost you are going to see.
* Cubic inch. The larger the engine the less boost it will make with a P-1SC.
* Headers and exhaust. A better flowing system will produce less boost, requires a smaller pulley to regain the loss in boost. Ultimately though, more power will be gained.
* Camshaft and heads. A camshaft with some overlap will leak out some boost through the valves. Better flowing heads react a lot like a better flowing exhaust system.
* Altitude. Elevation plays a big part in how much boost is produced. Those people living in the higher elevations have to spin the blower harder to see boost.
* Condition of engine. An engine with real good sealing rings will ultimately produce more boost than one with worn rings.
* Rpm. An engine that is spun up higher in the rpm range will normally produce more boost.
Bob
Old Feb 22, 2008 | 11:24 AM
b727pic's Avatar
13 PSI on my set up.....See sig
Old Feb 22, 2008 | 01:57 PM
powermad's Avatar
With an underdrive pulley running to a 4.25 incher on the blower I made 4lbs on my P1SC-1. I haven't been able to boost my new setup
Old Mar 5, 2008 | 12:31 PM
mycar2fast's Avatar
well i have an 8lb pulley not sure on the crank pulley size but i only get 6-7 lbs out of it. any ideas why?
Old Mar 6, 2008 | 04:37 AM
EPP's Avatar
EPP
Exclamation
There is no such thing as an 8 lb pulley, due to the variables involved.
Bob
