4.8L harness question??
Old 02-22-2008, 05:55 PM
onestepfurther's Avatar
Default 4.8L harness question??
I have a 4.8L out of a 2007 Silverado that I am swapping into my '93 240sx. My only problem is that I dont have the engine harness, and I have yet to find one.
I was just wondering if anyone had one for sell or knows where I can buy one. Or even have one made.
All help is appreciated.
Thanks,
Chase
Old 02-22-2008, 08:13 PM
LS1MCSS's Avatar
There are several places that will custom make one for you, but they are expensive. I have an LS1 harness that I am planning to modify, but I don't know what all is different in the two. Maybe someone that knows the differences will post up.
Old 02-22-2008, 10:20 PM
jay_lt4's Avatar
Thanks,
Chase
you will need the harness, the throttle pedal assy, and the tac module if you are going to keep the engine dbw
Old 02-23-2008, 01:26 PM
^I was planning on converting to a throttle cable instead of using DBW.
Old 02-23-2008, 01:30 PM
408z28's Avatar
sent you a pm.
Old 02-23-2008, 01:34 PM
^replied
Old 02-23-2008, 01:42 PM
408z28's Avatar
If you have a 07 4.8, you can buy a older 99-05 (cable style tb) wiring harness, pcm, and tb. The engines are all the same.
Old 02-23-2008, 02:46 PM
Don't they have a different crank? With different reluctor rings?
Old 09-28-2011, 10:59 PM
topstring's Avatar
Not so.I just bought a new style 07 4.8 and trans for my malibu wagon..took the TB off to go swap with a cable drive from an 02 and they aren't even the same,and will not bolt up.I'm not sure what to do short of exchanging intakes.
Old 09-29-2011, 07:18 AM
LS1Tech Sponsor
psiconversion's Avatar
You can buy an aftermarket Cable throttle body that has the 4-bolt mounting pattern.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 09-29-2011, 04:47 PM
topstring's Avatar
Do you have any links ?
Old 09-30-2011, 07:03 AM
LS1Tech Sponsor
We have used these....
http://www.summitracing.com/parts/EDL-3869/?rtype=10
Jon
PSI
__________________
Ebay Store
Quick Reply: 4.8L harness question??
