what is the best atifreeze to use in a 99 ls1?
Old 02-23-2008, 05:10 AM
bigfatls6's Avatar
Default what is the best atifreeze to use in a 99 ls1?
I am fixing to change my thermostat to a 160 and I am going to flush the radiator while I am at it. WHat atifreeze should I replace it with?
Old 02-23-2008, 10:00 AM
DrkPhx's Avatar
Since you just swapped the T-stat just use Dexcool. These cars used Dexcool from the factory and that's what I have always used in mine regardless of the setup. Even though it's considered an extended care product, I recommend to change it annually.
Old 02-23-2008, 10:09 AM
cookba's Avatar
i flushed the entire system about 2 years ago and have been using G-05 ever since
Old 02-23-2008, 03:35 PM
ae13291's Avatar
go green man!! when i flushed my system at 77k i had chunks of brown dexcool and there was corrosion in the cooling system because of dexcool! we use the green in all our cars now!! dexcool should be only used on the newer cars systems with the pressurized secondary tank!
Old 02-23-2008, 04:15 PM
Viper's Avatar
Green here on my 3rd motor. Dexcool sludged up my heater core and I had to change it out.
Old 02-23-2008, 08:33 PM
bigfatls6's Avatar
Whats the best way to flush the system out good enough to cange to the green anti freeze? I know your not supposed to mix the two.
Old 02-25-2008, 09:32 PM
FMX05's Avatar
Someone answer this guy because I need to know too. My coolant looks like watered down coke lol.
Old 02-26-2008, 12:45 AM
waldershrek's Avatar
It does not matter what color and/or brand you chose. Just do not mix coolants. Get it flushed and replaced with whichever color you want and stick with it.
Old 02-26-2008, 02:28 AM
ae13291's Avatar
just go with the green!! trust me you wont have any problems
Old 02-26-2008, 02:54 AM
spy2520's Avatar
change any coolant regularly and you wont have problems. doesnt matter what color if you treat it right.
Old 02-26-2008, 10:16 AM
slow's Avatar
I change mine every couple of years, and it has always been orange coming out.
I woudl never wait 75K on a dexcool car.
Ryan
