Oil level in pan
Oil level in pan
How far fom the top of the pan is the oil level supposed to be when "full?" I'm doing a swap into a 71 vette and I don't have the original dipstick for this six liter. I have a lokar dipstick and it looks like the level should be right at the bottom of the windage tray. That seems a little high to me.
What does the stock stick say?
Thanks, Tim
Thanks, Tim
Motor is a truck 6.0, pan is also truck, but modified heavily. It looks a lot like an F body pan now, 5.5 inches deep, 14" long sump. I should have just bought one of those right off the bat, but this way was $200 cheaper.
The lokar dipstick goes straight in and it looks like "full" would put the oil level right at the bottom of the windage tray. I think that's too high. Someone has to have a picture of the a stock motor with the pan off. I really just want to know how high the oil is supposed to be on a stock motor. I don't know if my dipstick is accurate or not. I can't compare it to the stock one because it was rusted in and broke.
ok, i ran out and took a meas of my dipstick-with the d/s installed in the tube, i measured from a point where it hits the block (there is a rib thats on the tube that hits the block, about 5/16" above the o-ring) to the fill mark, and it is 4 7/8"
so basically about 4 13/16 to 4 7/8 below the block is fill
i have a caddy cts pan & matching d/s, but i would think all fill levels should be the same
hope that helps, there were 2 other holes in the stick for low oil, i can meas them if you wanted, for low oil
it seems to be pretty straight, i think the hole in the block is at a little bit of an angle-i can shoot a pic of the stick/tube later
one thing i prob didnt make clear when i said below the block, i ment below the d/s hole in the block, to be aprx 4 13/16 to 4 7/8" to fill
