1/8 mile run.
Old 02-24-2008, 10:04 PM
Britt2020's Avatar
Default 1/8 mile run.
I went to the track today and was just wondering how these # paired up to everyone else and what i could do to improve them.
r/t: .846
60: 1.96
330: 5.42
1/8: 8.28
mph: 86.42
.....This was my best run. http://www.youtube.com/watch?v=dY-Z6QSaRT4
Old 02-24-2008, 10:31 PM
redt/a2000's Avatar
Well 60 ft is kinda high so i imagine you were on street tires. aim for 1.75 in your 60 with slicks or drag radials. My bone stock 1999 t/a ran 8.2 with a 1.8 60 ft so your about right
Old 02-24-2008, 11:00 PM
Britt2020's Avatar
Yeah I was on street tires, I couldnt grab comming out of the hole.
Old 02-24-2008, 11:06 PM
crmartin99's Avatar
hard to tell when you didn't provide a mod list
Old 02-24-2008, 11:11 PM
Britt2020's Avatar
LS6 Intake, Cam, Underdrive pulley, 3600 stall, cut out, Slp lid, Holley Air filter,Free Mods. Was running 275/40/17 (worn out).
Old 02-24-2008, 11:14 PM
crmartin99's Avatar
get some DR's and that will fall dramatically, my guess would be in the 7.8-9 range.
Old 02-24-2008, 11:18 PM
Britt2020's Avatar
That would be great..thanks for all the info guys...Ill take all i can get.
Old 02-24-2008, 11:46 PM
jsteele90's Avatar
wow for all your mods that is slow. you definately need to find some traction. you have the power but you gottaa put it down. get some drs and some suspension work youll be flying
Old 02-25-2008, 01:44 AM
redt/a2000's Avatar
Honestly you should at least be going 7.5 with your mods. You may need a tune because your 60 ft wastn horrible and you should have at least went 8 flat worst would be 8.1. Hell stock i have went 8.7 with a 2.1 60 ft. i would bet money you dont have a tune with your set up.
Old 02-25-2008, 01:57 AM
jessedale98's Avatar
What are the specs on the cam?
and i'll be seeing you later this week, im in durant too
Old 02-25-2008, 10:32 AM
Britt2020's Avatar
Dont Know cam specs, was installed before I perchased the car.
Here is my best run. http://www.youtube.com/watch?v=dY-Z6QSaRT4
Old 02-25-2008, 10:54 AM
ping2day's Avatar
Last year with similar mods but with stock cam i was in the high 7's with Et Streets. You need traction with a converter. I don't have numbers yet this season with 100 more HP.
Old 02-25-2008, 11:05 AM
Ryans_pewter_ss's Avatar
I have drag radials and full exhaust, lid, 4.10's and went 7.80
Old 02-25-2008, 11:12 AM
Britt2020's Avatar
Yeah the biggest mod between you and I is the 4:10 and the exhaust that alone is worth all of mine.
Old 02-25-2008, 11:36 AM
redt/a2000's Avatar
Hell the 4.10's are only worth 1.5 to 2 tenths at the very most
Old 02-25-2008, 11:41 AM
Britt2020's Avatar
Is that compared to my 273's?
Old 02-25-2008, 04:20 PM
redt/a2000's Avatar
yeah at the very most assuming you hook great 2.5 tenths still at the most. Plus the fact that its a bad gear for a 10 bolt. makes it twice as weak and much more likley to break. The pinion gear is tiny and cant take much of a launch at all.
Old 02-25-2008, 04:40 PM
Britt2020's Avatar
I see. so 373 is the better ratio for the 10 bolt?
Old 02-25-2008, 07:23 PM
redt/a2000's Avatar
really 3.42 is probably the best gear for strength but 3.73 are still much stronger than the 4.10's. If it wont handle a launch why have 4.10's. Thats the reason everyone wants 4.10's right. quicker accel. Well 4.10's are useless on street tires youll spin all day. But they wont handle slicks so whats the point. 4.10's if you have a 9 inch or a 12 bolt other wise a bad idea.
Old 02-25-2008, 07:50 PM
danhr's Avatar
3.73's, unless you can live with 4.10's in the rear
your reaction time was horrible. let off the brake when the 3rd yellow light turns on, not the green light.
get some lca's and maybe lca relocation brackets and sticky tires to work that 60' down
and i think ur tune is the sux
Quick Reply: 1/8 mile run.
