Idle quality of a 110 LSA cam....
Old 07-16-2003, 09:13 PM
quickWS6's Avatar
Default Idle quality of a 110 LSA cam....
I have a 227/227 .599"/.599" cam ground on a 110 LSA. The idle is erratic, to say the least. Does anyone have a cam ground on a 110 LSA? What do you idle at? How much tuning did it take to get it to idle right? Any thoughts are appreciated.
Old 07-16-2003, 09:28 PM
Cal
Cal's Avatar
Default Re: Idle quality of a 110 LSA cam....
Sounds right to me. I'd have the idle set to at least 1000 rpm if that bad boy was in my engine.
Old 07-16-2003, 09:31 PM
FrankSS's Avatar
i have a 112 in my car with 224/.581 cam and it idles great at the stock level, 650 i believe...its all in the tuning...i might get a 110 though, jsut to bring the powerband down, so i dont have to turn crazy rpm's
Old 07-16-2003, 09:35 PM
Scalpel's Avatar
My buddy has a Futral cam on a 110 LSA, no tuning, idles awesome.
Old 07-16-2003, 10:46 PM
gator's 99TA's Avatar
the key is Alan futral's program, he is a genius. mine idles nice and no surging issues with a 230/230 on a 111 lsa (comp xe)
Old 07-16-2003, 10:49 PM
kyz28's Avatar
that's my cam...... we just drilled the throttle plate a little and it idles fine..... but then again, i kinda like it to be a little erratic
Old 07-16-2003, 11:21 PM
alexWS6's Avatar
anyone got a sound clip of a 110?? All you guys who have them in your A4s...any regrets??
Old 07-16-2003, 11:46 PM
bigeller's Avatar
I have a 111 LSA in mine.. The set screw has been bumped up for idle and it's untuned. I can't rev it as it's not broken in yet.. Right click and save as..
http://pages.sbcglobal.net/bigeller/Z28/RearDvrZ2.mov
http://pages.sbcglobal.net/bigeller/Z28/sideZ28.mov
[color=green]Mods to my 1999 Z28 are:<!--color--></font>
2002 Cadillac Escalade LQ9 6.0 10:1 engine.
Stock 6.0 D port heads
TSP 228R cam 228/228 .588/.588 111 LSA +2 ground in + 2 more by us.
Hooker Longtubes
Mufflex 3" to 4" Y no cats
4" Mufflex/spintech single out
Lingenfelter intake tapped for direct port jugo
Vig 3200
3:73s
Old 07-17-2003, 12:41 AM
kyz28's Avatar
there are sound clips of mine (M6) here:
https://ls1tech.com/threads/showflat...14&amp;fpart=1
Old 07-17-2003, 01:30 AM
8POTS's Avatar
Have a cam 228/228 @.050 580/580 110 LSA and it idled perfectly...just a tiny bit of lump but really nice.
Nothing like having nice tight lobe angles, particularly when you are going for bigger cams. Reels in the power band in to a usable spread. Not great for emissions though
The secret is in the tuning and having sufficient RPM at idle. Mine was set to 1000-1100 rpm.
Old 07-17-2003, 01:31 AM
LSX Mechanic
Damian's Avatar
I have a 230/230 110 on a stock idle speed, idles fine
josh
Old 07-17-2003, 01:48 AM
jaberwaki's Avatar
well looking at your sig unless your hiding it, you got stock bore and stock heads??
i am not sure that the lsa is your prob... yeh that is going to give you a real lope but i think i would look at your lift... 599! wow i thought 581 was kinda maxing it out on a stock bore/head motor...
could be wronge but thats my.02
Old 07-17-2003, 01:51 AM
quickWS6's Avatar
The G5X2s run more lift then I do. But the lift won't affect the idle.
Old 07-17-2003, 02:05 AM
jaberwaki's Avatar
didn't know they were that big! wow.. but i wasn't saying that the lift was causing the lope i was wondering about p/v clearance? but if you say bigger ones dont have trbl then so be it
i have been wronge b4
Old 07-17-2003, 09:42 AM
redz_02's Avatar
since you have a standard split it should idle fine. IF you had a big split like 10 degrees than you would get some ground rattlin loap.
Old 07-17-2003, 09:53 AM
quickWS6's Avatar
You talking to me? I don't have a split at all.
Old 07-17-2003, 09:55 AM
RoyO's Avatar
Ive got a 230/230 comp xe with.575 lift and a 110lsa. Ill let you guys know how it works out.
Old 07-18-2003, 07:05 PM
*Bad Trader*
BYBYC5's Avatar
someone try a 224/110
Old 07-18-2003, 08:21 PM
Cal
Cal's Avatar
I'm afraid idle quality is a bit subjective; anything 220 degrees duration and up with less than 116 degees LSA will not idle like the stock cam did. And the way the PCM is tunned will have a big bearing on it also. You could probably even make the stock cam lope if you slow down the idle enough. The only way you will ever know is to try the cam in questiou in YOUR car with YOUR tuning.
Old 07-19-2003, 08:26 AM
*Bad Trader*
BYBYC5's Avatar
well that depends, i know someone that has a 220 on a 114 and you cant even hear it. i also knew someone with a 224/114 with stocl maifolds and it was noticable until he said somthing.....but then again it depends alot on the idle speed and header/catback setup.
Quick Reply: Idle quality of a 110 LSA cam....
