My 383 crank/rods into ls2 block?
Old 02-26-2008, 06:43 AM
lstvr's Avatar
Default My 383 crank/rods into ls2 block?
Hi Guys, i can buy an ls2 complete engine brand new for the right money.Can i put my 4"eagle crank and rods onto the stock pistons that are in the ls2 unit. It would obviously save me a bit of money if i can do this. Thanks.
Old 02-26-2008, 07:09 AM
99ssleeper's Avatar
No you cannot. What kind of rods are they? The rods you have are probably 6.125, so you would need pistons with a shorter compression height. Plus, your rods probably have .945" floating pins.
Old 02-26-2008, 08:32 AM
lstvr's Avatar
Damn.
Old 02-26-2008, 12:30 PM
Grimes's Avatar
well he means that you cant use the stock pistons. you can obviously get aftermarket pistons to use with your crank and rods.
