Timing chain question
Old Feb 24, 2008 | 06:55 PM
VENOMIZED03's Avatar
Default Timing chain question
I have a 01 Z06 with the LS6 obviously. I just recently purchased a MS4 cam kit and I was wondering if you guys think I need to buy a new timing chain. If so, which one? I think I used the LS2 timing chain kit on my old SS but wasnt sure if I need one in this car. All opinions would be great.
THANKS
Old Feb 24, 2008 | 09:07 PM
LS1Silverado05's Avatar
THANKS
Yea man. I would say just do the chain. Its so cheap, its better just for the piece of mind. I also just went with the LS2 chain when I did my cam. I think it was maybe $35 from SDPC
Old Feb 24, 2008 | 11:42 PM
55LS1's Avatar
Can you run the LS2 chain on the LS1 sprokets?
Old Feb 25, 2008 | 01:31 AM
kingsey's Avatar
Im almost 100% u can run the ls2 chain on the ls1 sprokets.
Old Feb 25, 2008 | 08:42 AM
SOMbitch's Avatar
Yes you can.
Old Feb 25, 2008 | 01:13 PM
55LS1's Avatar
Cool, thats what I'm going to run!
Originally Posted by SOMbitch
Yes you can.
Old Feb 25, 2008 | 07:51 PM
sounds good to me. Thanks for the info guys
Old Feb 25, 2008 | 08:54 PM
ws6_bandit's Avatar
Yup ls2 chain will work on an ls1. Just finished my cam swap today and i went with the ls2. Also when we did my install we realized there was 1/4 to 1/2 inch of slack in the chain. That is normal so don't worry.
Old Feb 25, 2008 | 09:03 PM
kwiksilverz28's Avatar
Agreed to all of the above. LS1 sprockets with LS2 chain, and there is minimal slack. Make sure it is lined up. I put it together, rotated with socket, and verified lined up.
Old Feb 25, 2008 | 11:36 PM
SuperSport4life's Avatar
Do you have the G5X4 Cam indicated by your sig? Do you think the LS2 would be up to the task of a high revving cam like that? Do you think anything above an LS2 Chain (ie double roller) would be overkill for a cam like that?
Old Feb 25, 2008 | 11:48 PM
Camaro396's Avatar
I have a LS2 chain with a MS4.
Old Feb 26, 2008 | 02:04 AM
LebaneseShowoff's Avatar
I thought about a double roller, but the LS2 chain is pretty good, much stronger than the LS1 chain. Just had my cam swapped a couple days ago, i would also recommend the ported LS6 oil pump, since you can never be too safe.
Old Feb 26, 2008 | 09:55 AM
Well thats good to know, I am going to be installing a t-rex in a couple of months with some heads. I guess I will go with the LS2 timing chain, I have heard people have install problems with the Double roller and they have had to modify stuff to make the dr chain fit properly. I am probably going to go with a melling oil pump, on of my friends had one and swears by it. I am in a delima with the oil pump though, I only have 23k on my car and I have an LS6 oil pump stock, I could probably leave it but I think I will change it to be better safe then sorry.
Old Feb 26, 2008 | 01:24 PM
ws6_bandit's Avatar
Ya i think the ls2 is more than okay. I hear of plenty of people going with that chain and being fine. You probably would be fine with a ported ls6 oil pump also. That is what i went with and it holds about 60-70 psi cold. and 50 warm.
