blower speed-RPM calculator formula?
I believe the D1 kit comes with a 7.25 crank pulley and 4.5" blower pulley which is suppose to be about 8psi. Can anyone verify that?
If so I'm at 42936rpm and its making about 10psi on a stock LS1 and I've still got another 19000 to go
Not sure about the F body, but the GTO was a 7" crank pulley. I had a custom 8" pulley made by ASP to get my RPM's up on the impeller yet still keep enough belt wrap on the blower pulley to keep belt slip to a minimum.
responded to your PM.
If you dont have Excel you can't open it.
If you do have excel not sure why it wont open??? I can always email you the calc, but you will need MS Excel or excel reader...
