carb. and pcv valve
Old 02-27-2008, 06:39 PM
forcd ind's Avatar
Default carb. and pcv valve
i am running a carb, and have an lq4 style engine-the pass side v/c has a tube pointing toward the front, and the d/s v/c has one in the back pointing straight up-how are you guys with carbs doing the pcv setup, i dont think the engine actually has one, just the vent tubes-on older engines, one of the v/c's was equiped with the pcv valve, the other one was the air inlet, usually from the aircleaner or a breather-does a gen 3 suck out of both v/c's?
Old 02-28-2008, 08:18 AM
Shawn MacAnanny's Avatar
They say just put breathers on. Here is the thread i saved for when i get to that step
https://ls1tech.com/forums/conversions-swaps/845016-help-pvc-system.html
Quick Reply: carb. and pcv valve
