Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
350 SBC setup
Old 02-27-2008, 07:07 PM
UpOnOne781's Avatar
Default 350 SBC setup
Could anyone send me their setup in their 350 cuz i cant decide on a setup or wut cam to get nd all that...Im lookin for about 350 horse...
Old 02-27-2008, 07:44 PM
In-Zane Moderator
ZONES89RS's Avatar
Man, you arent asking for mutch, a set of BS 350 heads with 64 cc chambers and a small cam will get you that if you have 9 to 1 compression. 1 hp per cube is too easy.
Old 02-27-2008, 10:05 PM
UpOnOne781's Avatar
i was lookin to get at least 350, i wasnt sure i should build it much bigger than that cuz i didnt wanna give it more then it could handle...people told me that since its not the four bolt main and i was originally gunna boost it that i prolly shouldnt, but im just lookin for a street/strip car nd id love to have 400+ hp if i could for a reasonable price without boost...if u have a better set up im open to ne suggestions you guys got for me...Thanks
Old 02-28-2008, 03:48 AM
In-Zane Moderator
ZONES89RS's Avatar
Well, the 383 is optimal for a budget. I have 1000$ in my 383 in my 89, i kill LS1s with bolt ons and pulls HARD even with a junk 2.73 gear. You canget a set of vortec heads and a 383 stroker kit and make 425+ hp and 450+ ftlbs tq. Enough to make anyone smile. A 2 bolt main is good for 500 hp with no problem as long as you stud the mains.
Old 02-28-2008, 09:12 AM
UpOnOne781's Avatar
i wanted to get the 383 kit but i decided not to because of the gearing in the car i was originally gunna use, so i got a rebuild kit nd need a cam, heads, intake, carb and all that. but now im getting a trans am nd im just looking to build a motor thats gunna get me at least 350 to the wheel...i want a cam that will give me a little rough idle and give me some good torque nd horse power...im lookin to make most of my horse power before 5500 rpm..any suggestions??
Old 02-28-2008, 03:19 PM
In-Zane Moderator
ZONES89RS's Avatar
Wow....what does the gearing have to do with it?
Well, vortec heads are cheap and make plenty of torque and power. Use them.
Old 02-28-2008, 04:53 PM
UpOnOne781's Avatar
I didnt want a car that was always runnin high rpms..its gunna be my daily driver except when i ride my bike...but thanks for the advice...
Old 02-28-2008, 06:59 PM
In-Zane Moderator
ZONES89RS's Avatar
well, the thing is man, a 383 with vortec heads and a minor cam will make 400 ftlbs....at 3500 rpm or so, the crusing speed can be kept low and run great. I have a 383 in my car with a 2.73 gear, i cruise at 1100 rpm at 50 or so, damn near idling. Not what i want but it does its thing for now.
Old 02-28-2008, 09:48 PM
a-mean-89-iroc's Avatar
My setup is a 355 4 bolt main with forged srp pistons. 10.5:1 compression, Ported aluminum heads. Cam was 230 236 @ 0.50 but swapped it out now for a 240 246 because the heads flowed enough air for it. Got a edelbrock victor jr. intake with a holley hp series 750 carb. Havent got it dynoed with the new cam yet but i will but should be pushing a bit over 350 rwhp. and it runs really good even with my stock 2.77's. It will feel alot better once i put my gears in it. Basically a build for nitrous though. Thats what i wanted and im planning on running a 150 shot.
Old 02-29-2008, 03:47 AM
In-Zane Moderator
ZONES89RS's Avatar
You and me need to run, i have a-mean-89-RS with 2.73 gears LOL! Mine pulls HARD for the gear that is in it, i bet i would pull you down low since i technically should make more low end power, would be fun.
Old 02-29-2008, 09:03 AM
UpOnOne781's Avatar
nice..im lookin at the XE268H comp cam...you guys heard anything about this paticular cam??
Old 02-29-2008, 10:54 AM
Yea pretty good size cam. Im pretty sure im thinking about the same one you are. You going to need some good flowing heads though.
Old 02-29-2008, 10:56 AM
I guess there would only be one way to find out huh! Im sure yours pulls harder since youve got more tq. 383's put down good tq. Once i get my gears she should be pullin on you lol!
Old 02-29-2008, 03:47 PM
UpOnOne781's Avatar
What kinda heads you think would go good with it...im lookin for 64 CC heads and im lookin to spend under 700 if i could...i was lookin at cast iron heads even...
Old 02-29-2008, 07:41 PM
camaroboricua's Avatar
Check out the article "Wake -Up 'stick" on chevy high performance. Their 383 had the XE268H using Dart 200cc heads on a 69' Nova put down 353rwhp @ 5,800 and 375 lb-ft of torque @3900 granted this is on a 383 with some big heads but the article might give you an Idea of what to expect.
Or do a search for articles on an engine build called danger mouse...that one helped me quite a bit....
Quick Reply: 350 SBC setup
