Squeeky driver door hinges...........
Old 02-28-2008, 09:07 PM
needadvice's Avatar
Default Squeeky driver door hinges...........
Whats the best grease or lub to use to stop the damn squeeking?
Old 02-29-2008, 12:29 AM
fuseone's Avatar
what ever you might have around actully i had some sea foam deep creep said it was a lubercant on it so i used that helped.
Old 02-29-2008, 01:41 AM
go-t's Avatar
I just sprayed WD-40
Old 02-29-2008, 04:46 AM
johnnybravo's Avatar
Rem-oil. Green aerosol can w/ yellow cap. Available at your local sporting goods store.
Old 02-29-2008, 07:46 AM
Save the manuals!
wssix99's Avatar
I got turned on to SuperLube, which is recommended in the factory service manual. It has worked really well for me and lasts a long time. Its a PTFE lubricant, which will not wash away like WD-40 or other regular oils will.
SuperLube also comes in a "Precision Oiler" (picture attached) which has a special tip for things like hinges. (It also works well for wet location hinges inside the house, like bathroom doors.)
Old 02-29-2008, 10:13 AM
needadvice's Avatar
Where do they sell it?
I've tried WD-40, lasted one week. I've tried white grease and it lasted a couple weeks, I also tried 3-N-1, didn't last.
Old 02-29-2008, 12:19 PM
Save the manuals!
wssix99's Avatar
3-N-1 wears off just like the WD-40. They are also solvents, so they tend to disolve rust and create goo. (then you no longer have an oiled surface)
The only place I've seen the SuperLube Precision Oiler has been at Menard's - maybe also at Ace or a local HVAC shop, but I don't recall exactly... You can also do a google search and find it online at a lot of places.
Old 02-29-2008, 01:16 PM
needadvice's Avatar
Thanks, I found it on google. I'll give it a shot.
Old 02-29-2008, 05:52 PM
SparkyJJO's Avatar
Mine is squeaking/groaning when I open the door too. Irritates me, sounds like a bad door on an old beat-up car..... wait, my car is fairly beat up....
Old 03-24-2008, 03:25 PM
LETHLS1's Avatar
WD40 will solve your problem.
Old 04-17-2008, 10:10 PM
needadvice's Avatar
UPDATE on what works perfectly.
I simply poured a cap full of engine motor oil on top of each hinge and let it drip and run down through the entire hinge. Hasn't made a peep in almost 4 weeks and its still nice and wet all around the hinges.
Pretty funny!
Old 04-18-2008, 12:35 AM
Wsteun's Avatar
I sprayed mine with WD40 like 2 months ago. Haven't heard anything from either door.
Old 04-18-2008, 01:43 AM
Kevano26's Avatar
^worked for me. I usually do it like once a year.
Old 04-18-2008, 12:08 PM
needadvice's Avatar
I drenched mine with WD-40 a couple times, only worked for a few days.
Motor oil is awesome. The doors swing open effortlessly now and they're finally silent.
Old 04-18-2008, 01:11 PM
Greggy's Avatar
how about antiseize compound spray. It won't drip or wash away.
Old 04-18-2008, 01:57 PM
PonyTamr's Avatar
Im a huge fan of white grease. that **** is vicious on sqeeks.
Old 04-18-2008, 02:03 PM
EvoWake's Avatar
old motor oil. i keep some in a lipton tea glass just for this reason
Old 04-18-2008, 02:16 PM
98FreakZ's Avatar
white lithium gease works wonders!
Old 04-24-2008, 10:59 PM
silverbandit0996's Avatar
i borrowed some stuff from work called sani-lube, its for lubing things in a kitchen. it foams up and stays there for weeks, and it quiets squeeks even longer.
Quick Reply: Squeeky driver door hinges...........
