IS A CUT-OUT WORTH THE$$$$$$
Old 07-18-2003, 01:28 AM
ChazLS12002's Avatar
Default IS A CUT-OUT WORTH THE$$$$$$
Is a cut-out worth the $$$ or should I use it for something else? How does it sound? Don't you lose power? And...
How does the electric one work, I don't want wires or holes everywhere because it's a 2002
THANKS ALREADY
Old 07-18-2003, 02:18 AM
Moderator
LIL SS's Avatar
Default Re: IS A CUT-OUT WORTH THE$$$$$$
Just dynoed today with and with out cutouts.. Back to back. With open headers I picked up 7hp and 12flbs.. See dyno results in internal section.
Old 07-18-2003, 11:54 AM
Restricted User
CAT3's Avatar
Chaz, yes its wortht the few $$$, and I would stick with original cutout over the electric, unless you like blasting around the streets attracting attention to yourself. I picked up over 2mph and about 2/10th in qtr.
Old 07-18-2003, 01:11 PM
bspz28's Avatar
it's worth the money for sure.. I say get it
Old 07-18-2003, 01:16 PM
SS GIRL's Avatar
i was going to ask the same thing...... i have been trying to talk my bf into getting some but he isn't interested at all!!!!
Old 07-18-2003, 01:18 PM
Restricted User
CAT3's Avatar
bspz28-nice launch. what size front tires if ya dont mind?
kissmySSgoodbye-stop talking and just do it. he wont know until you uncap 'em.
Old 07-18-2003, 01:25 PM
Thanks, 4 the replys, but how is the electric one setup??? I plan on installing either one myself
Old 07-18-2003, 03:56 PM
Pat-Man's Avatar
The elctric setup is pretty nice and very convient if you don't like getting under the car and putting the plate back on (which is hard to do when cruising around town and cops randomly appear at your side). The install was pretty straight forward...the only problem I had was mounting my switch. I had to cut the wires to the switch, mount the switch in my custom plate I made to fit my ash tray, then I had to splice and resolder the wires. Time consuming, but not hard at all. - Pat
Old 07-18-2003, 06:02 PM
Moderator
LIL SS's Avatar
My switch install was a breeze. Decided to go in the ashtry. Pulled the top of the consel off, unbolted the trany boot and slid the wiring up through there. Took less than an hour to do the duals
Old 07-18-2003, 06:10 PM
mike c.'s Avatar
hay guys,is the electric cutout as quiet as the regular one is when closed? or does it leak and make more noise? thank's
Old 07-19-2003, 12:03 AM
jpz28's Avatar
A cutout is worth the money and the sound...... ......extra HP!! and extra loudness!!!!
Old 07-19-2003, 08:59 AM
BigPlanTransAm's Avatar
mine didnt leak when i got, then it started to leak, then it stopped. all on its own. they say all you have to do it put some silicone where the piece that moves touches the plate and it will stop leaking.
