M/T P315/30R18 Two in stock $310.00 ea
Tire Size: 315/30-18
Rim Diameter (in): 18 in.
Sidewall Style: Blackwall
Tire Construction: Radial
Directional: Yes
Tire Diameter (in): 25.50 in.
Minimum Recommended Rim Width (in): 11.00 in.
Maximum Recommended Rim Width (in): 12.00 in.
Tread Width (in): 11.00 in.
Section Width (in): 12.40 in.
Asymmetrical Tread Pattern: No
Tube Required: No
Tire Compound: R2
DOT-Approved: Yes
Extreme traction on the strip, drives you home on the street.
Mickey Thompson's legendary race tire technology comes to the street with these all-new ET Street Radial tires. Built using the latest in high-tech radial construction techniques and years of drag racing experience in compound development, these DOT approved, street legal drag radials will get your car down the track in record time and still provide you with an excellent ride on the way home. Other important features include reduced rolling resistance, a low-void directional tread pattern for maximum dry-weather traction, and polyester ply/steel belted construction for long lasting strength and durability
